It is currently Wed Jul 15, 2026 8:56 am
Post new topic  Reply to topic  [ 1356 posts ]  Go to page Previous 1 2 3 4 591 Next
PostPosted: Sat Jul 25, 2009 1:55 pm
frank,
use www.photobucket.com
Create an account and choose the files to upoad.
photobucket dosent care if it's a mac, PC linux or a phone.
Copy the IMG code from the pics in your gallery to a message post.
PostPosted: Sun Jul 26, 2009 7:36 am
Thanks Greg Ill try that.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
 Post subject: 7-26-09
PostPosted: Sun Jul 26, 2009 12:47 pm
Well I got the fuel cell in and Secured down.
The Trunk floor is much more solid now with the box below the fuel cell.
I am waiting to get a few more small adapters to connect all the Fuel lines up to the pump.
I also Put on the spring clamps today as well.
Fuel Cell Inside
Fuel cell below / Box enclosure.
Spring clamp
 Post subject: 7-28-09
PostPosted: Tue Jul 28, 2009 2:01 pm
LR Wheelhouse / Quarter Panel Atatched. And I got all the small bits to finally connect up the fuel cell. No more 2 Gallon can under the Hood!
LR Body patch Pics:
Now to get the brakes worked out.
PostPosted: Fri Jul 31, 2009 12:42 pm
Well I stared to Wire A bit of the engine compartment for some of The electricial componet upgrades. I figured I would do this now While I have time With the Old Engine / Trans in place instead of waiting until I get the Engine / trans Done.
Suff I have done since Last Update:
Catch Can ala 77 volare style.
Elect Fan Money Shot
Fan 2
Electrical Command Center
Pro Matic 2 Shifter installed with Momentary Switch for Line Lock
Shifter Shot 2
Maybe I can hit the Track next week for a baseline :) as the car can drive on it's own now.
PostPosted: Sat Aug 01, 2009 8:25 pm
This is just to cool :D :lol:
PostPosted: Mon Aug 03, 2009 11:34 am
Wow, you are way ahead of me, Greg. Looks like fun!
PostPosted: Mon Aug 03, 2009 5:10 pm
Yes Lou I am for now.. I really thrashed on this thing like for 4 weeks straight 4-8 hours a day over this summer.. I might do a shakedown TNT on wed. with it. I will have more pics of other junk I put on over the weekend..
But I am thinking that you might catch up to me as I will be putting in like 80+ hours / week in at work during Sept- October and This project will come to a screeching halt untill after halloweeen..
BOO!
PostPosted: Mon Aug 03, 2009 9:22 pm
Update: I Got the Tach and other Gauges installed. Everything is prettymuch Wired up except for the Electric Water Pump drive Which I will Get To after the Engine Build.
The Electronic Ign Dist Is On with A faster Advance Curve and Better Wires. Along with this is the MSD Box. I also Put a solid motor mount on the Drivers Side But Forgot to get A pic.. If you have seen steel before then You get the idea :)
Upgraded Ign:
Removed Heater Nipple and Used the Port for the mechanical Temp Gauge
Tach Installed and Communicating With the MSD box
Gauge Cluster
PostPosted: Thu Aug 06, 2009 8:02 pm
Yep So I ran the car at TNT last night.
I will post a pic of the car with the race wheels and tires; which are waay lighter than the old steelies.
Anyway,
Here are The Passes on a 1968 Bone Stock Motor / Trans with hundreds of thousands of miles on it.
Run 1 - In "D"
60' - 2.53
1/8 - 12.10 @ 54.23
1/4 - 19.54 @ 64.67
Run 2 - Removed Air cleaner - Shifted 2-3 Manually
60' - 2.50
1/8 - 11.96 @ 55.38
1/4 - 19.23 @ 66.52
Run 3
60' - 2.53
1/8 - 11.97 @ 55.96
1/4 - 19.13 @ 67.56
Run 4
60' - 2.50
1/8 - 11.98 @ 54.86
1/4 - 19.25 @ 66.55
It Sure Seemed like Everything was in slow motion Compared to running the dart.
Hopefully Next year I can post some 13's or faster with this machine!
PostPosted: Sun Aug 09, 2009 3:50 pm
Nice to get some baseline runs so you can say you chopped 6 seconds off the times later!
PostPosted: Sun Aug 09, 2009 5:03 pm
Yeah That's what I am talkin' About! Also there were some folks Belive it ot not who wanted to check this thing out in the lanes.. One Guy Liked the "Rat Rod Look" it has to it.
Later,
PostPosted: Sun Nov 29, 2009 8:52 am
Hello Everyone,
It's been a bit of time, but absolutely nothing has happened to the Ruster Racer since the last post - Marching band and football have taken over my life until this thanksgiving break. Beside spending time with friends and family, I am giving thanks to the slant six engine block, Gathering up some robust speed parts and Making sone necessary Block mods!
Well I did a basic Clean and inspect of the block Tapping all threaded holes And Lots of studying of Doc's playing with blocks and Oiling system prep articles. This block Came from a 64 Truck So it's yellow. I have had it in the basement for years and The Cylinders are so badly pitted I figured it would be a perfect canidate for the .104" overbore. It had sat in the dirt for years and The head was sceapped a long time ago due to the valves being frozen in it. I Got Me a Long 5/16 Drill fron the Crank and Main feeds - Also Lots of oil pump Gallery Passage smoothing.
Pistons are assembled on rods with pin locks and rings - These will get sent to the machine shop to get balanced and then Ring fitment time when the block comes back.
Also the Head is shown Grinded, tanked and ready to go to Mike Jeffries To work The Nebraska Magic.
(many Pics to Follow) long Post.
PostPosted: Sun Nov 29, 2009 11:15 am
Looking good Greg!!
11.02 @ 120.56
Chassis dyno
PostPosted: Thu Dec 03, 2009 2:47 pm
Tom, thanks for the words of encourgament.
Here are some Shots of the Transmission Tear apart Clean and Rebuild. I will be putting in new bands, Clutches and a trans go TF 3 Valve body From Tom. This is kinda fun because I have never really tore apart an auto trans and put it back together before this.
