It is currently Sun Nov 22, 2026 6:12 am
 Post subject: is my engine dead
PostPosted: Wed May 14, 2003 7:13 am
i have a 69 valiant.It 's a 170,it was running great.Good compression,great gas mileage.Then going down a hill i felt like i was losing power,the oil light came on.I pulled over the car was still running but making a bad bumping,knocking sound from down low.I had it towed.Oil was fine.It still starts,i pulled the valve cover,with it running i didn't see a lot of oil .
did i spin a bearing?
Should i pull the engine?
is there anything i should check while the engine is still in the car and running?
thanks for any help
PostPosted: Wed May 14, 2003 9:11 am
Contributor
Oil lights and loud noises when oil level is normal usually indicate a dead engine.
My guess is a spun bearing which usually announces itself with a groaning, scraping sound.
PostPosted: Wed May 14, 2003 9:12 am
It sure sounds like a spun bearing.
Look around for a replacement engine, that way you can "switch" and keep the car together rather them having it sit around with the engine out.
Dd
Users browsing this forum: Amazon [Bot], DuckDuckGo [Bot], Google [Bot] and 7 guests
