It is currently Thu Nov 12, 2026 8:19 am
PostPosted: Sat Aug 29, 2009 8:00 pm
i just put a new alternator on my 69 dart 225 ci.it is 50 volts/amps single pulley.after i changed it it still was discharging,so i replaced the voltage regular.i started the car,at idle is was perfect,dead center.as soon as i stepped on the gas it pegged itself to full charge and stayed there while driving,but at idle speed it was ok.i grounded the regulator on the car so it wouldn't over charge.what might be the problem?is it safe to keep over charging the system?
any help would be appreciated.
thanks
butch
PostPosted: Sat Aug 29, 2009 9:01 pm
Get a voltmeter and see what the voltage is.......
PostPosted: Sun Aug 30, 2009 4:25 am
I agree get an reading with a meter to find out how much voltage you are putting in the system, it definitely is not a good idea to run an overcharging car something will fry or the battery could explode.
1956 Dodge D100 Pick up
power plant 225 slant six
PostPosted: Sun Aug 30, 2009 9:03 am
on the 62 lancer there is a engine to body ground...If this ground gets loose or even dirty some times the bat. gauge goes nuts...way over charging...
Its so nice out side, I think I'll go lay under my car..
