It is currently Sun Oct 11, 2026 1:58 am
 Post subject: More on porting ?'s
PostPosted: Wed Aug 12, 2009 12:25 am
Car Model: 1965 Dart 270 w/ 66 Valiant front clip
When porting a head, are the side walls important to port as well? I've done the roof of the ports and blended the bowls. Should I just call it good or keep on grinding??
Michael Glass. Mopar stuff and some rusty Mopar stuff!
1965 Dodge Dart with 66 Valiant front clip. Other stuff...
PostPosted: Wed Aug 12, 2009 5:55 am
I would just smooth the sidewalls, and not remove much material at all. The bowls is where almost all of the gain is. I knock the guide bosses down quite a bit too.
 Post subject: Re: More on porting ?'s
PostPosted: Thu Sep 03, 2009 7:39 am
At some point you should measure the approx cc's that each port is displacing: Not real important unless you are taking out a lot of metal.
Mike Chilando
Alkydigger@yahoo.com
WWW.Alkydigger.com
615-483-6830
nashville TN
PostPosted: Mon Sep 14, 2009 6:23 pm
Almost all the horses in any head are hiding in the valve pocket or bowl.The rest is almost for apearance sake. not quite but by comparson to the rest it often seems so. You can make a quick testor with a vaccum cleaner and sonmeABS pipe and a u tube made from a ruler and clear plastic tubing. It wont read CFM but it will tell you when the port flows better and Vaccum will fall on the home made guage as flow increases (assuming the source of the vaccum remains constant. ) It will also tell you your ports ideal cam lift.
Some people will be able to catch on right quick how to use this crude but effective device and others will not understand it or want to critique it.. If you can see how it would help use it. If not dont worry about it.
Don
