It is currently Fri Nov 20, 2026 7:10 pm
 Post subject: A-904T identification
PostPosted: Thu Oct 01, 2009 9:45 am
Is there a quick and easy way to determine if a transmission is an A-904T with the wide ratio gearset as opposed to an A-904 if the transmission is just sitting out loose?
Thanks.
PostPosted: Thu Oct 01, 2009 10:33 am
I don't know if there is an easy way but most of the 80's lock up transmissions have the low gearsets (Fifth Ave, Fury, Imperial...etc)
11.02 @ 120.56
Chassis dyno
PostPosted: Thu Oct 01, 2009 4:48 pm
You could read and post the trans number stamped into the kickdown-side trans pan rail...
PostPosted: Thu Oct 01, 2009 4:58 pm
True, but I need to know so I can spot one to buy in a boneyard.
PostPosted: Fri Oct 02, 2009 2:23 pm
Can anyone decode this trans #?
4130413 6529 1068
PostPosted: Fri Oct 02, 2009 3:09 pm
Looks like it is from a 1979.
http://www.mymopar.com/downloads/transguide.pdf
I have a 79 service manual and it still shows the standard gear ratios (no low gear sets avail):
2.45 first
1.45 second
1.00 third
2.21 reverse
11.02 @ 120.56
Chassis dyno
PostPosted: Fri Oct 02, 2009 3:15 pm
Thanks,didn't want to offer it up to Reed if it wasn't what he was after. 8)
PostPosted: Fri Oct 02, 2009 3:24 pm
Hey, thanks for thinking about me though!
:D
Users browsing this forum: Amazon [Bot] and 2 guests
