It is currently Fri Nov 20, 2026 10:19 am
 Post subject: 65 904 trans
PostPosted: Mon Oct 05, 2009 9:27 pm
I'm wondering what it takes to make a 65 904 pushbutton trans work in my 63 wagon(pushbutton as well). Is the 65 pushbutton a 1 year only make?
63 valiant v200 Wagon 9.5, Schneider cam, E.I. 22 mpg all day
PostPosted: Mon Oct 05, 2009 10:19 pm
Car Model: 1962 Lancer 770
just to be clear, the 65 isn't technically a push button, but it still uses the 2 cable system with a column shifter, instead of a push button shifter.
MJ
PostPosted: Tue Oct 06, 2009 4:14 am
MJ
To use a 65 cable shift trans with a 60-64 PB shifter, you only need to swap out the valve body (use the 64 VB in the 65 trans). Another option is to just install the 64 "manual valve" and shifter detent "comb" , into the 65 valve body.
PostPosted: Tue Oct 06, 2009 8:24 am
Charlie I believe he has a 63 PB, could he put his 63 VB in, or is there a specific reason it has to be the 64? Thanks!
MJ
PostPosted: Tue Oct 06, 2009 8:52 am
'60-'64 pushbutton valve body (or components) are what's needed for the swap.
PostPosted: Tue Oct 06, 2009 10:13 am
ty sir, that's just what we needed to know
MJ
PostPosted: Tue Oct 06, 2009 10:45 am
Yes, Dan is correct.
 Post subject: THAnks
PostPosted: Tue Oct 06, 2009 7:33 pm
thanks for all the fast replys! I'm going to make it work, no worries!
