It is currently Thu May 07, 2026 7:36 pm
 Post subject: HEI coil and module
PostPosted: Thu Oct 08, 2009 2:56 pm
this is kinda pointed at Slant six Dan. I have a napa coil lying around # IC29. it has 4 female pins on it and looks simialar to the coil you show in the thread on the hei swap. are the pins the ignition module? just different connector configuration?
thanks
Jared
64' Valiant Signet 5.9, 64' Dart 170 moredoor 3.7, 67' A100 3.7, 00' Dakota SLT 4.7
PostPosted: Thu Oct 08, 2009 3:28 pm
Mmmm...donno!
It'll probably work fine if you can figure out the polarity and get the correct connectors for it.
PostPosted: Thu Oct 08, 2009 5:55 pm
actually I think they are the connections for the coil. + and -
PostPosted: Thu Oct 08, 2009 10:22 pm
Well yeah, that's the kind of connections one finds on a coil, is coil connections. :-)
There's no module built into/onto this coil.
PostPosted: Fri Oct 09, 2009 5:39 pm
6 Pack Dart
In the picture the connecter closest to front are for the 12 volt input and tach lead (the one closest to coil output is for 12 volt input), on the other side (closest to output of coil is for the + connecter from the ign module and the other connector is for the C connector from the module).
You can buy the black and gray conecters from any parts store (ign coil pig tails)
