It is currently Sat Jul 18, 2026 11:13 am
PostPosted: Wed Nov 04, 2009 3:27 pm
I finally got my slant put back together after cleaning up the valves ,and replacing the seals. It seems to be getting 18hg . I think my cruise control has a small leak in it , because the vacuum stopped bouncing a little ,when I capped off the cruise. On to the question,does the air cleaner vacuum port on the carb have constant vacuum? I pulled the hose off of it and had no vacuum coming from it.
Thanks for any replies
Dave
81 Dodge D150
It looked easier in the book .
PostPosted: Wed Nov 04, 2009 3:43 pm
What carb and what port? Ports on the carb can have all vacuum all the time or all vacuum some of the time, depending on their intended function.
PostPosted: Wed Nov 04, 2009 3:56 pm
Holley 1920,the port that goes to the aircleaner temp sensor.
It is the port on the passanger side up front of the carb.
Dave[/url]
81 Dodge D150
PostPosted: Wed Nov 04, 2009 4:22 pm
Yes. That should be a constant vacuum port.
PostPosted: Wed Nov 04, 2009 4:32 pm
I will check again tommorrow, but I am pretty sure it did not have any .( hopefully I am wrong ).What could be the cause of not haveing any?
The gasket is on correct , the hole that is on the gasket is on the passenger side and to the front of the intake manifold. The carb is new (from Dan) .
Dave
81 Dodge D150
PostPosted: Wed Nov 04, 2009 4:43 pm
:shrug:
If the gasket is installed correctly over the hole in the intake, then you are either on the wrong nipple on the carb or there is a blockage somewhere.
PostPosted: Wed Nov 04, 2009 4:47 pm
Yeah , I guess I will take the carb off ,and check everything out. Thanks for the help,I don't have much time to work on it , and I am glad I was able to get every back on it before it got too cold.
Dave
81 Dodge D150
PostPosted: Wed Nov 04, 2009 9:01 pm
The air cleaner vacuum port on the 1920 is on the driver's side near the bottom, not on the passenger side. Don't know what port you're looking at; refer to Figure 1 in the 1920 manual you linked.
PostPosted: Thu Nov 05, 2009 2:15 pm
Dan , you are right , and I am a moron for putting down passenger side :oops: . I took the carb off and looked at it ,and found out the reason it did not have any vacuum ,was that it wasn't getting any.
I cut a slit out of the hole( with a razor blade) in the gasket, to open it up to get vacuum , and now it operates the air cleaner flapper as soon as it is cranked up.
Thanks for the help
Dave
81 Dodge D150
PostPosted: Fri Nov 06, 2009 2:31 pm
I take it that the older intake manifolds have a hole for that ports vacuum, but since mine is newer and had a different carb on it ,that is why it wasn't getting vacuum ,until I cut the slit going to the hole to get vacuum to that port.
Is that right?
Dave
81 Dodge D150
PostPosted: Fri Nov 06, 2009 3:00 pm
Yup, that's correct.
