It is currently Sat May 09, 2026 10:23 am
PostPosted: Thu Nov 05, 2009 8:37 am
i believe the voltage regulator on my 68 225 dart is not the right one. its over charging my batteries cause it looks like a hack job plus the other dart i had. had a different one as well. can someone help? please thanx
68 225 Dart "life under the hood, is the life for me" -By Me
PostPosted: Thu Nov 05, 2009 8:51 am
If the system is overcharging, the voltage regulator could be faulty. Have you tried replacing it?
 Post subject: im confused
PostPosted: Thu Nov 05, 2009 8:55 am
the voltage regulator that is in my system, is not the regulator that should be there i want to get the original one and rewire it. what could be useful to do this.
 Post subject: here
PostPosted: Thu Nov 05, 2009 9:02 am
i dont know if u cant tell but heres a pic of what i have.
let me know if its good, if not ill try to go out there and take a big pic.
 Post subject: hey Dan.
PostPosted: Thu Nov 05, 2009 9:15 am
just an idea have u guys, thought about going youtubeish in this forum, to help out in a visual kind of way when explaining procedures that would be awesome, to download vids and show whats going on with the members. just some food for thought.
PostPosted: Thu Nov 05, 2009 9:17 am
Can't see anything there — your pic is less than an inch tall and about a half inch wide.
The best voltage regulator for the pre-'70 cars is a Standard Ignition #VR-128 or NAPA Echlin #VR-1001. It has a slightly different appearance from the original, but fits and hooks up the same. If you want one identical to original, use Standard #VR-101 or Echlin VR-32
Before you buy anything else, you'll want to buy the books described in this thread to get you up to speed on how the various parts of your car work and how to fix them.
 Post subject: thanx
PostPosted: Fri Nov 06, 2009 9:07 am
i will do that thanx.
PostPosted: Tue Nov 17, 2009 10:12 pm
heres the pics of the intruder lol
Image Image what you think?
PostPosted: Tue Nov 17, 2009 10:47 pm
Correct me if I am wrong, but isn't that a Ford voltage regulator? Looks like someone spliced the plug into the wiring harness. I believe I see e-tape near the plug.
PostPosted: Wed Nov 18, 2009 12:19 am
i think so, im not very famliar with ford, but it surely dont belong in my dart and its over charging my batteries. i want to bring it back to normal.
PostPosted: Fri Dec 04, 2009 8:35 pm
looks like a ford regulator to me
PostPosted: Sat Dec 05, 2009 8:40 am
What you can also do is update your system with the newer style voltage regulator is you not a purist. In my van I went to the JY and snagged the alternator, wiring, and reg from a 74? something Mopar and installed it. You'll get a bigger amp alt. and a great charging system. NOW, if you have already upgraded the alt, then just do the reg. and wires. Here's a link with info. Good Luck http://www.imperialclub.com/Repair/Elec ... arging.htm
