It is currently Sat Nov 21, 2026 10:41 pm
PostPosted: Sat Nov 07, 2009 7:46 am
We are doing a super six swap. Aluminum intake is not threaded for a sensor that the old 1bbl is.
Anything that will keep us from passing non visual smog check?
The other hole is getting used for the power brake line.
PostPosted: Sat Nov 07, 2009 7:15 pm
Nope. If they're not doing a California-style visual inspection against a specific list of every last widget that's supposed to be on that particular car, as long as the car's tuned correctly and running properly you'll pass smog no problem.
PostPosted: Sun Nov 08, 2009 5:10 am
Any idea what that widget is? There is a place cast into the #6 runner. It isn't drilled or tapped.
PostPosted: Sun Nov 08, 2009 5:42 am
Only thing I have ever seen in that place is a vacuum tree with about 6 lines coming off of it of various sizes. :shock:
PostPosted: Sun Nov 08, 2009 6:17 am
That is threaded into the other hole. There is a 2 wire sensor that goes into the other one.
I want to see if this thing passes the test in Nashville with the air pump siezed.
PostPosted: Sun Nov 08, 2009 6:53 am
Rug
If it doesnt I have a good working pump off of my 82 truck. I can drop it off next time im thru.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Sun Nov 08, 2009 4:30 pm
Thanks for the offer. He may pass without the pump. IIRC he passed last year.
Users browsing this forum: Bing [Bot] and 8 guests
