It is currently Sat May 02, 2026 1:24 am
PostPosted: Sat Nov 07, 2009 7:46 am
We are doing a super six swap. Aluminum intake is not threaded for a sensor that the old 1bbl is.
Anything that will keep us from passing non visual smog check?
The other hole is getting used for the power brake line.
'72 Duster 198 stock cam, 3:23's Hookers on jack stands for 8 years in the driveway
'79 Maxivan 360 Offy Qjet Comp RV cam/rusting in the driveway.
93 D350 160HP Cummins Auto :-( Dually Clubcab needs a injector pump
2005 Golden Couch Buick
PostPosted: Sat Nov 07, 2009 7:15 pm
Nope. If they're not doing a California-style visual inspection against a specific list of every last widget that's supposed to be on that particular car, as long as the car's tuned correctly and running properly you'll pass smog no problem.
PostPosted: Sun Nov 08, 2009 5:10 am
Any idea what that widget is? There is a place cast into the #6 runner. It isn't drilled or tapped.
PostPosted: Sun Nov 08, 2009 5:42 am
Only thing I have ever seen in that place is a vacuum tree with about 6 lines coming off of it of various sizes. :shock:
PostPosted: Sun Nov 08, 2009 6:17 am
That is threaded into the other hole. There is a 2 wire sensor that goes into the other one.
I want to see if this thing passes the test in Nashville with the air pump siezed.
PostPosted: Sun Nov 08, 2009 6:53 am
Rug
If it doesnt I have a good working pump off of my 82 truck. I can drop it off next time im thru.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Sun Nov 08, 2009 4:30 pm
Thanks for the offer. He may pass without the pump. IIRC he passed last year.
