It is currently Mon Nov 16, 2026 12:56 am
 Post subject: a 100 trans
PostPosted: Tue Nov 10, 2009 6:43 pm
I am changing an A-100 truck with a 3 speed to a 904 auto. Has
anyone tried this conversion? What type of trans support will
I need? The trans I have has a different tail shaft than the
trans in the truck for support!!
Any help will be appreciated. Thanks
Craig
PostPosted: Tue Nov 10, 2009 6:46 pm
A quick question before diving in. Do you know how to weld?
PostPosted: Tue Nov 10, 2009 7:03 pm
Hi,
Thanks for the response. Yes I have access
to a welder.
Whats next??
Thanks Craig
PostPosted: Tue Nov 10, 2009 7:17 pm
The A904 only has a mounting pad on the bottom of the tailshaft. You'll need to make a big collar that surrounds the tailshaft to put a mount in the same position as the original trans. Or you could fab a new transmission crossmember.
How do you plan on shifting the 904? Aftermarket cable shifter is probably easiest. Unless the 3-speed is the same length as the 904 I'm sure you know you'll be having a new drive shaft made.
BTW, what year is the A100?
PostPosted: Tue Nov 10, 2009 7:31 pm
I have measured the two trans, and they are of
different lengths. I was just wondering if someone
has made trans supports for these conversions. Yes
I will have to make a new drive shaft.The A 100 is a
1968 with a 225 and has fairly nice body. I will be
doing a complete re-do. Hope to be completed in a
year or so.
Thanks Craig
PostPosted: Tue Nov 10, 2009 9:16 pm
Craig is the A-100 a van or pickup?
PostPosted: Wed Nov 11, 2009 9:11 am
Craig,
Join the Yahoo A-100 group and you'll find some pics of a conversion using a B-van crossmember tied in to the A-van subframe. Pretty slick install and looked fairly easy.
-James
PostPosted: Wed Nov 18, 2009 2:41 pm
Pm me if you need pics of the stock 727 setup. I dont have any at the moment but can get take em if you need em
64' Valiant Signet 5.9, 64' Dart 170 moredoor 3.7, 67' A100 3.7, 00' Dakota SLT 4.7
PostPosted: Sat Nov 21, 2009 5:27 pm
pics of the truck ?
Nothing beats a slant six
1987 D150
PostPosted: Tue Apr 06, 2010 11:52 am
Craig,
I bought an A100 PU with a /6 and 904. This was a swap done about ten years ago by someone who I don't know. It was pretty slick. The automatic uses the original 3 on the tree shifter for the auto. I'll get some pic as soon as i can. :shock:
64 A100 PU 170 /6
Salisbury, NC
