It is currently Sat May 16, 2026 12:59 am
Post new topic  Reply to topic  [ 17 posts ]  Go to page Previous 1 2
PostPosted: Sun Nov 15, 2009 5:43 pm
Running a hotter plug at the end cylinders often solves the fouled plug deal... some think the fuel doesn't stay atomized long enough to make it to the end cyls. causing a rich mixture.
Check it out... www.symcoshakedown.com
PostPosted: Sun Nov 15, 2009 7:23 pm
sv162 will tell you that doesn't work as well as it would seem. He had some pinging in response to hotter plugs as reported in another thread about rich conditions on plugs 1 and 6. I assume you still have manifold heat? This has helped others with fuel condensation in the two longest runners. Also if you removed the lean burn carb you should get a standard distributor and ignition box. The lean burn stuff was all meant to work together so the remaining parts are working against the progress you made with the carb swap.
72 dart acquired 12/08 /6,holley2b, mopar perf intake, mopar perf header, cam, built motor,904 finally re-installed, 8.75....still needs sorting out.
99 dakota 318 5 speed reg cab picked up 9/09; Trans finally fixed! woohoo!
Users browsing this forum: Google [Bot] and 24 guests
