It is currently Fri May 01, 2026 10:41 am
PostPosted: Mon Nov 16, 2009 6:54 pm
I need to purchase all the manifold studs, but none of the parts people have them listed by motor, so I'm curious what the size and threading is, if anyone knows, thanks, Mark I'm guessing ARP probably makes them.??
PostPosted: Mon Nov 16, 2009 7:19 pm
They are 5/16 x 1 3/4 with 1/2" threaded on each end; fine threads on one end and coarse on the other. Someone will probably chime in with a part number.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Tue Nov 17, 2009 4:50 am
Darn it. We talked about it at the Garlits show. That was one of the reasons you stopped at my place, and I forgot. You don't need ARP bolts, just get them at a local nut and bolt store. Just don't get cheap grade 5 studs.
PostPosted: Tue Nov 17, 2009 5:33 am
still trying for the Turkey Rod Run, thanks again, Mark
PostPosted: Tue Nov 17, 2009 6:25 am
Dorman brand makes what you need,don't have the part# handy but a GOOD parts guy can look it up by application.
 Post subject: thanks for all the info,
PostPosted: Tue Nov 17, 2009 7:52 am
I didn't think these would be difficult to track down, but they have been, thanks again guys!
PostPosted: Tue Nov 17, 2009 12:39 pm
Car Model: 71 Dodge D100 64 Plymouth Valiant Wagon
I was able to score some at the local O'Reilly. Sorry no part number, but it wasn't too hard. If you have one to show them it can help.
Best of luck,
Joe
Joe Hoppe
71 D100 225 Super Six 727 AT on 2008 Crown Vic CopCar frame
64 Valiant Wagon 225 904 AT 3:23 8.75"
PostPosted: Tue Nov 17, 2009 7:48 pm
The ones we got at O'Reilly were a tad long on the manifold side. They worked fine!
'72 Duster 198 stock cam, 3:23's Hookers on jack stands for 8 years in the driveway
'79 Maxivan 360 Offy Qjet Comp RV cam/rusting in the driveway.
93 D350 160HP Cummins Auto :-( Dually Clubcab needs a injector pump
2005 Golden Couch Buick
PostPosted: Thu Nov 19, 2009 3:28 am
NAPA stocks them too.
Good gun control is hitting your target repeatedly
PostPosted: Fri Nov 20, 2009 6:31 pm
new studs (Grade-eight) - Dorman Part # 675-093
Look here for measurements:
http://tinyurl.com/yapze35
Danny
PostPosted: Fri Nov 20, 2009 6:41 pm
Those will probably work, but the dimensions are different from the ones I removed from my head.
the one I have is 1 3/4" long with 5/8" of fine thread, 5/8" unthreaded shoulder and 1/2" of course threads.
David Kight
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Sat Nov 21, 2009 5:26 am
PostPosted: Sat Nov 21, 2009 6:40 am
The ones that are a little longer on the manifold side work fine. Just did it on "Ruby" the '80 model van.
