It is currently Tue Dec 30, 2025 12:51 pm
PostPosted: Sun Nov 29, 2009 4:46 pm
So, I bought an '85 Ram a while back and found out that the valves were stuck. I pulled the motor and bought a running 170 out of an early Valiant, thinking it might be cheaper than rebuilding the 225, because I think it has more problems than not.
I have been running into small things because the 225 was made for a truck, and the 170 obviously wasn't. So today, I went to put the 225 oil pick up on(because the pan is different), and found that it wouldn't fit. Any thoughts? Did I maybe bend the pick up? Has anyone ever tried this? Should I just give up on the 170 and go back to the 225 and hope that it doesn't need to be rebuilt?
Any thoughts would be greatly appreciated.
Thanks!
--Chad
'65 Plymouth Valiant 2dr post
'85 Dodge Ram
'73 Mercury Montego
PostPosted: Sun Nov 29, 2009 4:55 pm
the 170 head will fit on the 225
PostPosted: Sun Nov 29, 2009 5:26 pm
What year is the 170? There should not be a problem swaping the oil pan and pick up, BUT:
You mentioned early 170. If the engine is 1967 or earlier, you will be unable to use the auto trans from the 85 truck, with out buying a special torque converter. If the truck is a standard shift, you will need a early (1967 down) flywheel.
Check the hub and counter-bore size on the rear of the crankshaft before doing anything more.
PostPosted: Sun Nov 29, 2009 6:02 pm
Swapping the 170 will work if these issues are addressed, but it'll be way down on torque compared to a 225. Swapping the head and using the hydro valvetrain is one option,
PostPosted: Sun Nov 29, 2009 8:59 pm
Well, actually the 170 is a '62.. and the truck is a manual(so was the '62). Yeah, I realize that I will be losing some torque... hopefully not too much. I have the flywheel out of the '62 as well...
Any other thoughts?
Thanks guys!
--Chad
'85 Dodge Ram
'73 Mercury Montego
PostPosted: Mon Nov 30, 2009 6:19 am
Be forewarned, the 170 does fine in a car, but a heavy vehicle is a bit much for it. I had an extended box 70's Dodge Tradesman van that the PO swapped in a 170. I tuned that engine to where it ran like new, but it had such a hard time pushing that big van around. I had the gas pedal to the floor most of the time I was driving it, not an exaggeration here, it was wide open most of the time just to keep up with traffic. This got old after a couple of years and I swapped a 225 back in. The power gain was such a relief!
PostPosted: Mon Nov 30, 2009 1:55 pm
well... It sounds like maybe the 225 is the way to go... Maybe this project will have to be on hold for a bit...
Thanks for the input guys! I didn't realize that it would make that much of a difference!
--Chad
'85 Dodge Ram
'73 Mercury Montego
PostPosted: Mon Nov 30, 2009 2:10 pm
Living in Kansas might make that 170 a better pick than around here.
If you want to do 70 into a headwind on the Interstate you will want the 225.
Users browsing this forum: No registered users and 16 guests
