It is currently Wed Jun 17, 2026 11:18 am
 Post subject: Door Lock Solenoid
PostPosted: Sat Nov 28, 2009 4:38 pm
Help :
anyone have any idea where i can locate A Drivers Side Front Door Lock Solenoid for my 1987 Dodge B150 Van its not power its mechanical ???
thanks :D
PostPosted: Sat Nov 28, 2009 4:45 pm
Why would a mechanical-lock door need a solenoid? Do you mean the lock cylinder itself?
PostPosted: Tue Dec 01, 2009 6:23 pm
wrong terminology ~~ sorry about that ~~ my door closes real hard doesnt really seal also wont lock even if you lock it with a key or just push the button down ~~ im thinking the door latch ~~but i am open to any and all suggestions ~~thanks :oops:
PostPosted: Tue Dec 01, 2009 6:45 pm
Ok sounds like you need to hit a wrecking yard and pull the door latch mech and the striker pin.If the door is not closing tight you might still be able to adjust it however if it's been in slam mode for a long time it will take it's toll on the latch and striker.As far as not locking it's possible one or more of the lock rods has pulled out of the plastic clips that hold everything together.Question,does the door droop down when you open it?If you've been having to lift up on the door to get it to close then the hinges are shot and all that lifting and slamming has taken it's toll.Good luck
PostPosted: Wed Dec 02, 2009 7:32 am
6shotvanner :
thanks for your help ~~as for the door it doesn't need to be lifted that part is OK but as far as the rest of it you are dead on my friend ~~ thanks again i owe you one :D
PostPosted: Wed Dec 02, 2009 9:33 am
:) Been tripping over,on and in Dodge vans for years,glad to help.
PostPosted: Wed Dec 02, 2009 1:43 pm
yeah man i know what you mean ~~i have always been a Dodge vanner myself been thru them over the years ~~this 1987 Dodge B150 van slant six 225 3spd auto is kind of special to me it was my work van when i worked for the phone company , back then they sold them every 3 years i picked it up before it went to auction , i did some contract work out of it and then parked it and just cranked it once in awhile , then stupid me i let it sit for about 3years , i changed all the fluids dumped the tank put air in the tires some gas and it turned right over no problem ~~that slant six is one tough motor so now i am going to rebuild her and bring her back to life ~~~ i hope :D
