It is currently Thu Jun 18, 2026 8:29 am
 Post subject: spark plug tube seals?
PostPosted: Thu Dec 03, 2009 6:10 pm
silly question but were the heck to spark plug tube seals go on the slant ?
i recently started picking and my slant and doing a run over some of the common wear and tear items and tune up parts and i cant figure out where they go??
thanks
-frank
PostPosted: Thu Dec 03, 2009 6:20 pm
They go round the aluminum spark plug tubes found on '60-'74 cylinder heads. '75 and later heads do not have plug tubes, and therefore do not have plug tube seals.
PostPosted: Thu Dec 03, 2009 6:21 pm
6 Pack Dart
Remove spark plugs, then using your fingers pull the tubs out. You should see under the rim of the tube a hard black piece. Remove it and put the new seal in it's place.
PostPosted: Thu Dec 03, 2009 6:55 pm
Site Admin
Here Ya go! :D
CJ
PostPosted: Thu Dec 03, 2009 7:47 pm
please tell my you donnt have to take the valve cover off to to remove those? are they fairly easy to replace?
PostPosted: Thu Dec 03, 2009 7:55 pm
Site Admin
Nope! Just remove the spark plug, and pull the drool tube out.
Remember that the crush ring needs to be removed from the spark plug prior to installing in drool tubes. The aluminum of the spark plug tube seals the plug to the head.
While doing your tune up, it's still a good idea to pull the valve cover to lash the valves.
:D
CJ
PostPosted: Thu Dec 03, 2009 9:07 pm
thank you for your help i plan on getting the clifford adjustable rocker assembly and theres no chatter so i should be ok for now
PostPosted: Thu Dec 03, 2009 9:32 pm
H'm. Is this a race car you're building, or a driver? The stock rockers are adjustable and work well.
PostPosted: Fri Dec 04, 2009 6:52 am
Dont waste your money. Read up on Clifford BEFORE you buy from them. You can get the same thing cheaper from Rick at RAS.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Fri Dec 04, 2009 8:21 am
well it gives you a better lift duration .444 to .474
and mine could deffantly be replaced.
as far as the tube seals,i still cant find the drools?
is it possible that i don't have them its an 84 slant.
PostPosted: Fri Dec 04, 2009 8:23 am
oh and im trying to get it to rev as high as it can for a turbo setup that im preping for.
-frank
PostPosted: Fri Dec 04, 2009 8:32 am
72 dart acquired 12/08 /6,holley2b, mopar perf intake, mopar perf header, cam, built motor,904 finally re-installed, 8.75....still needs sorting out.
99 dakota 318 5 speed reg cab picked up 9/09; Trans finally fixed! woohoo!
Your '84 engine does not have spark plug tubes, so it does not use spark plug tube seals. It is also a hydraulic-lifter engine, which means the Clifford rocker set you have your eye on is not applicable. And yes, as has been said, Clifford has a pretty poor track record as a problematic vendor. Be careful, because they seem not to have any problem recommending and selling the wrong parts to slant-6 owners — see here and follow the links.
PostPosted: Fri Dec 04, 2009 8:33 am
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Google [Bot] and 2 guests
