It is currently Sat Jun 13, 2026 10:26 pm
PostPosted: Tue Dec 15, 2009 5:55 pm
Howdy, I was just wondering what everybody's favorite brand of oil filter is? The Runnings in a nearby town stopped carrying Purolators and switched to Fram and I DO NOT want to use Fram, so it peaked my curiousity of other brands.
PostPosted: Tue Dec 15, 2009 5:59 pm
Wix on my domestic stuff. Factory filters on my Acura.
-James
PostPosted: Tue Dec 15, 2009 6:27 pm
Napa Gold.
PostPosted: Tue Dec 15, 2009 6:44 pm
Wix group discount on moparts. Good service. I bought $200 worth for me and my friends.
http://board.moparts.org/ubbthreads/sho ... art=1&vc=1
11.02 @ 120.56
Chassis dyno
PostPosted: Tue Dec 15, 2009 6:58 pm
+1 Wix.
Check the fine print (BTW): NAPA Gold IS Wix.
obliquely-inclined state of mind
PostPosted: Tue Dec 15, 2009 7:13 pm
Wix, Hastings, Purolator, or even (shock!) Motorcraft are on my "yes" list.
Fram, K&N, Amsoil, and all the off-brand filters are on my "NO!" list.
The giant canonical comparative oil filter study is here.
Special filters worth knowing about are the Wix #1806 (which has a built-in standpipe so oil won't drain down the middle even if your oil pump hasn't got a standpipe on it) and Wix #1773 (which is an extra-tall filter for greater dirt capacity and less flow restriction).
PostPosted: Tue Dec 15, 2009 8:42 pm
+1 Wix.
I knew Napa Gold was a rebrand, I just couldn't remember which one. I generally use a Napa Gold 1806 (with the standpipe), but, after reading Dan's comment above, I might try running a 1773.
PostPosted: Tue Dec 15, 2009 8:44 pm
The Pep Boy filters are from Purolator.
Identical when I cut some apart years ago...........
PostPosted: Tue Dec 15, 2009 9:51 pm
I use the 1773s when I'm trying to clean up an engine that is especially sludged, or if I'm using costly synthetic oil and long drain intervals.
PostPosted: Wed Dec 16, 2009 7:27 pm
Wix 51515 or the Motorcraft if they don't have the Wix.
Linder Tech.com
Bubba's Trailer Park
 Post subject: Oil Filter Alternatives
PostPosted: Thu Dec 17, 2009 9:20 am
I've started using Fleetguard filters but I haven't seen very many evaluations of this brand other than on BITOG. I don't know if Fleetguard is better or worse than Wix or the other better filters. They tell me that they are the OEM filter supplier for several hundred companies and have a non-prorated warranty. Cummins calls their synthetic media filters StrataPore. See BITOG: Fleetguard Stratapore LF16002 for a dissection.
The equivalent filter to the one Dan recommends (Wix 51806 / Napa Gold 1806) is Fleetguard LF701.
The Wix 51515 cross-references to Fleetguard LF551A, LF3313, and LF3487 (synthetic media)
The Wix 51773 cross-references to Fleetguard LF697 and LF787
PostPosted: Thu Dec 17, 2009 12:43 pm
Once again, Thanks Dan! I have known about BITOG for several years but never thought much about filters (other than Fram sucks)! I have only run synthetic oils since 1981 and looks like now I will only use Wix/Napa. :D
PostPosted: Fri Dec 18, 2009 7:39 pm
Fleetguard LF699 is a large version of the LF701 oil filter with standpipe. From their catalog: Overall Height 174.24 mm (6.86 in).
Olaf.
Aspenized
