It is currently Mon Nov 09, 2026 6:13 pm
 Post subject: Tachometer question
PostPosted: Sat Dec 26, 2009 10:58 am
Hi,
I bought a tach for my Charger. It says it's calibrated for an eight cylinder, and modifying it will void the warranty.
Will it work with the slant?
Thanks!
John D
1968 Dodge Charger 225 a833 OD
1962 Valiant 170 2 door post car
1962 Valiant Signet (junker right now)
1962 Valiant Signet, one owner car, waiting for me to pick it up. Scratch that-got it!
PostPosted: Sat Dec 26, 2009 12:14 pm
6 Pack Dart
Depends on mfg of tach, some are set up for 8 cyl but have instructions on how to set up for 4 or 6 cyl.
PostPosted: Sat Dec 26, 2009 3:22 pm
If there aren't switches or a wire loop to cut to change the number of cylinders the tachometer will read properly then you need a different tach.
PostPosted: Sat Dec 26, 2009 8:31 pm
Thanks for the info guys.
I got my tach from chargerspecialties.com. I'll call them on Monday to figure out how I can get it to work. They manufacture them so I hope they can tell me how to modify it, or make me one that will work.
I'm just glad that I realized it might not work before I put the cluster back together! Putting it back in the car and having to pull it again wouldn't have been fun.
Thanks again,
John D
PostPosted: Mon Dec 28, 2009 5:41 pm
Hi Guys,
Talked to the manufacturer, and he said there is an adjustment on there, but I would need another tach to confirm the new setting.
I mailed it out to him to re-calibrate it. Seemed easier.
Thanks again,
John D
