It is currently Thu May 21, 2026 3:33 pm
PostPosted: Fri Jan 08, 2010 5:18 pm
I am Putting the cam in for ruster and I do not have a head yet.
I just want to ballpark the Timing Gears - I have the tilley timing set with the adjustable top gear and the torrington bearing. I do see a mark on the bottom gear but nothing on the top a'la Stock style.
How do I go about lining this up?
I beleive a few other folks Might have used Cameron Tilley's Gear?
Thanks,
PostPosted: Sat Jan 09, 2010 9:08 am
I am probably the only one. Just installed it ("just" - 3 mo ago) and the cover is on it. I don't remember seeing a mark either, but I think I just fooled with it until I got it right. IIRC, I used the cam pin and an old cam gear to see where it would go. I scribed it when I figured out where it was supposed to be.
Hope this helps,
PostPosted: Sat Jan 09, 2010 10:59 am
Ahh - Good Call The old Cam pin trick should do it - I'll get that old gear out of the heap for a rough Mark!
PostPosted: Sat Jan 09, 2010 6:58 pm
At TDC exhaust stroke, the cam pin and the crankshaft keyway are straight-up, in relation to the top deck.
PostPosted: Sat Jan 09, 2010 7:28 pm
That sounds familiar. Thanks, Doc.
