It is currently Wed Oct 14, 2026 1:19 pm
PostPosted: Wed Jan 20, 2010 3:16 pm
Anyone have any ideas or pictures on what to use for a kick down with a holley 2300? Its going into a 67 Dart with clifford long tube headers(old style)and a 904. I have heard you can use the supersix kickdown,but am not sure if it will fit with my headers?
Thanks :D
PostPosted: Wed Jan 20, 2010 6:03 pm
See this thread for kickdown options.
PostPosted: Thu Jan 21, 2010 11:05 am
Thanks Dan! Anyone have any pictures of what they are running?
PostPosted: Thu Jan 21, 2010 3:44 pm
Im running the stock kickdown. Using the 2280 Holley or the BBD. The long tubes didnt get in the way. Hope that helps.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
 Post subject: Stock bits here too
PostPosted: Thu Jan 21, 2010 4:25 pm
I used the stock slotted top piece w/ spring, and stock bottom bit that plugs into the trans lever. Inbetween I welded a bent up piece of 5/16" round stock to clear my 6 into 1 headers.
Just make sure the point on the throttle linkage on your holley that you use for the k/d pin is about the same distance from the pivot to give the right amount of travel.
good luck
madam im adam
PostPosted: Fri Jan 22, 2010 10:30 am
Thanks Guys,it very much helps!
PostPosted: Sat Jan 23, 2010 4:26 am
This is the system with this adapter that I use, no fabrication needed, bolt on, adjust, and drive off. It will fit any future carburetor and engine changes as well.
