It is currently Thu May 14, 2026 11:12 pm
PostPosted: Mon Feb 01, 2010 2:07 pm
Pretty much what the Subject line says I think I want to use some ngk race plugs Any good known part #'s for a non peanut head for a 12:1 No boost no nitrous engine?
PostPosted: Mon Feb 01, 2010 5:47 pm
I have always used Autolite 63s with good results.
PostPosted: Mon Feb 01, 2010 6:31 pm
I have had good service from Autolites, also. However, Autolite has been shifting production to China, so look at the box, to see where the plugs were made. I would use made in USA, maybe made in Mexico, but never made in China.
PostPosted: Mon Feb 01, 2010 6:48 pm
Champions were made in the U.S.A but last year I discovered they were now made in Mexico (from the previous year). I even sent them a letter letting them know I expected a price decrease since their labor cost was now lower...no response.
11.02 @ 120.56
Chassis dyno
PostPosted: Mon Feb 01, 2010 9:00 pm
Great question cause our builds are so very similar,I do want to push mine closer to 12.5 but the plugs probably should bee the same.On kinda the same subject what is recomended for a 10.7 motor?Guzzi Mark
PostPosted: Tue Feb 02, 2010 6:33 am
I use NGK V-powers in my stuff. GR5 is 2 heat ranges colder than the stock recommended GR4. Heat range is reversed --> higher number = colder. I run GR4 or GR45 in my current engines.
I'm no expert, and have never had anything over 11:1, just my 2 cents.
 Post subject: Plugs
PostPosted: Tue Feb 02, 2010 7:38 pm
I run RN9YC OLD CHAMPION # .Cross to your favorite brand.
I have the Race Hemi plug # at the shop .Not sure of the Brand but for a 14 to 1 engine. I will get that for you for comparison.
 Post subject: Plugs
PostPosted: Wed Feb 03, 2010 11:14 am
The Champion race plug # N59YDR or #N61YDR
PostPosted: Wed Feb 03, 2010 1:18 pm
cool. Thanks for the info.
I Will be going with NGK - I really like them and I have do do a bit of research on them but I can probably get it fired on some old plugs from the dart for now.
 Post subject: Plugs
PostPosted: Wed Feb 03, 2010 3:25 pm
I use the Champion # because I had a chart. FYI I had thought about the new E3 plugs so I looked them up and they use the same plug # for all the heat ranges From N9Y to N17Y. So I questioned them on how could this be in their Tech Forum and got no responce. Guess they don't really want to sell sparkplugs.
 Post subject: Re: Plugs
PostPosted: Tue Feb 23, 2010 8:12 pm
new E3 plugs
Gimmicky trash from China. It's all sizzle, no steak. All hat, no cowboy. All litterbox, no cat.
PostPosted: Wed Feb 24, 2010 6:11 pm
Yes Guys I dis use some of those Champions in the dart a while Back.
I have been doing a lot of research on spark plugs.com,
I have a finewire irridium NGK heat range 9 in the dart from over the summer. ET's went down. .06 Seconds and Picked up 4mpg using thsis plug vs other stuff.
I got some NGK fine wires for the Ruster Engine too. Just one heat range colder NGK 10 - Should be good - We'll see.
I can supply Part / stock #s if anyone cares.
PostPosted: Fri Feb 26, 2010 6:35 pm
Per Mikes suggestion,I am going to run R-5672A-9s, NGK.same engine combo as yours.Guzzi Mark
PostPosted: Fri Feb 26, 2010 8:04 pm
Yes Mark, I talked to mike on the Phone last night.
He told me about those too.
Thnaks for the post.
Get that motor movin before vegas Man or loose a six pac to doc!
PostPosted: Fri Feb 26, 2010 9:23 pm
Pulling motor out Sunday,have to change droplink,and going to modify k member.Will be fitting my borrowed rockers and make a dummy push rod for measurement,and send it to get some made.Depending on push rods I want to run the car next thurs with new motor.Will report.Mark
