It is currently Fri Jul 17, 2026 10:11 pm
Post new topic  Reply to topic  [ 1356 posts ]  Go to page Previous 14 5 6 7 891 Next
PostPosted: Thu Jan 28, 2010 9:12 am
Great progress for sure...what does a two piece timing cover look like? What is its purpose? I got a stock cover from Mike Jefferies with a cam button that he added for me.
What is the nearest SL6 race date to Canada on the east coast?
Thanks Derek
70 Duster 238'', four speed ,3:91's, 500 Elde, Hookers
68 Dart 4 dr 225, completely original
PostPosted: Thu Jan 28, 2010 2:18 pm
Thanks Lou.
Yes I hope to have the new drivetrain in the Car in march - That should allow for plenty of shakedown passes in here at PIT for April and May before hagerstown.
I am just waiting on stuff from Mike J pretty much now. I will probably make the Drain plug tonite and leak test the pan. I emailed midwest today so I should be getting a converter soon!
Derek,
The Closest northe east Slant race is In maryland about 5 Hours away From New York City.
Check Here:
http://www.slantsix.org/forum/viewtopic.php?t=38550
About a 19 Hour Dirve for you and ~1900KM trip.
The Split timing cover will have a cam button too.
It is used to access the adjustable timing gear - I will take a stock timing cover and basically slice off the top for an access point to the gear.
Like this one:
PostPosted: Thu Jan 28, 2010 2:50 pm
I know that motor, and it's not yours, methinks. I've turned wrenches on that cover, I believe. Where did that pic come from?
I just drilled 4 holes in the front 1" diameter and put caplugs in 'em. We'll see how that works...
Derek, if Hagerstown attracts some upper East Coast folks this year, then we will probably try to get a race going in NJ or NY in next or future years.
PostPosted: Thu Jan 28, 2010 4:44 pm
You're right Lou!
That's Cameron's motor money shot.
I think he emailed it to me a while back.
I have had it on my computer forever. I have the whole shot too.
Quite impressive.
PostPosted: Fri Jan 29, 2010 4:48 pm
Poser
Greg - Lou ,please explain the split timing cover cam button down under thingy!
PostPosted: Fri Jan 29, 2010 4:56 pm
It's simple really. Camoeron Tilley made some adjustable cam sprockets. With the 2-piece timing cover you can remove the top part and adjust the cam timing without pulling the damper and such. I might have to get one of his timing sets and fab my own 2-piece cover so I can do easy cam timing adjustments with the Bonneville engine.
PostPosted: Fri Jan 29, 2010 5:14 pm
The button keeps the cam from walking back and forth. Pretty simple, braze a 3/8th fine nut on the cover and use a rocker adjuster. :D
PostPosted: Sat Jan 30, 2010 6:00 am
Yep, WV,
Slantzilla and Josh beat me to it.
What they said.
PostPosted: Sat Jan 30, 2010 1:54 pm
Just finished up the oil pan.
I had 3 small leaks that I found on the leak test. Welded those up nice and tight. Put a 1/2-20 Magentic drain plug in From the parts store.
Now onto sizing up the dipstick and Getting the timing cover cut apart and modified.
PostPosted: Mon Feb 01, 2010 6:33 am
That is a good accomplishment to get it welded up leak free. Looks nice.
PostPosted: Mon Feb 01, 2010 2:05 pm
Thnaks Lou.- Yeah, leak free isn't really an option with an oil pan; It HAS to be leak free or else!
I think it looks quite ugly, but that's me.
Also Got a hold of midwest TQ's gave them my cam and Gear Weight and tire size etc. and They said My Converter should ship by the end of the week for $375 + shipping. ALso said it should stall around 4000 for this cam.
PostPosted: Tue Feb 02, 2010 6:42 am
I'll have some work to do to keep up with you at Hagerstown... What's your ET goal - 12s?
PostPosted: Tue Feb 02, 2010 3:08 pm
ET Goal? Who knows??
AFAP!
As fast as possible!
We'll see how it shakes down.
Is will definitely be a bit faster than the outing from august 2009!
PostPosted: Wed Feb 03, 2010 9:19 pm
Well My first Package from Mike arrived.
The Windage tray and scraper.
I had only small interference issues on the scraper for counter weights and Throws Near #1 and No clearance issues with the windage tray whatsoever.
Also Started laying out and building the Split timing cover and cam button.
Pics Below.
Enjoy,
PostPosted: Thu Feb 04, 2010 1:40 pm
Car Model: 1967 Dodge Dart 270
Looks Good!! :D
