It is currently Fri Jun 19, 2026 11:38 am
 Post subject: 8 3/4 question
PostPosted: Sun Feb 14, 2010 8:18 am
I just picked up a A body 8 3/4 housing and axles this week and found that the rear bearing on the passenger side had spun and did some damage to the housing. How do I go about fixing this so I can install it in my 64 Valiant?
Raymond Flynn
Registered Six Offender!!!!
PostPosted: Sun Feb 14, 2010 9:03 am
Car Model: 63 Dart 81 D150
I am sure that anyone would need to see pic's to really help you. A whole lot depends on how damaged the housing is, fixes range from easy to it's junk and/or cheaper to find another one.
TopHat
PostPosted: Sun Feb 14, 2010 9:21 am
I will post some pics tonight. The damage is where the bearing presses in it is gouged up a little bit not bad but I know a little off is a big deal.
Raymond Flynn
PostPosted: Sun Feb 14, 2010 10:43 am
Don't throw it away......
Worst case scenario would be to cut that side off and install a Moser housing. They are about $60.00 but well worth it and very good quality.
I had Moser housings installed on both sides on mine. I really like the 8 3/4 Sure Grip on my car......
