It is currently Sat Nov 28, 2026 12:42 am
 Post subject: 2bbl intake
PostPosted: Sun Feb 28, 2010 5:58 pm
Hi all,
Just wanted to know if I need a different exhaust manifold with a /6 2bbl intake or can I use my 1bbl exhaust manifold. Got a couple in my sights but need to know if I have to get a different exhaust manifold too. Thanks
PostPosted: Sun Feb 28, 2010 6:04 pm
No but... The exhaust manifolds will ALL work. You may run into choke pocket issues so an electric choke may be in your future.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Sun Feb 28, 2010 6:08 pm
6 Pack Dart
They are the same, good luck getting them apart. Soak the bolts with PB blaster for a whole before trying to remove them.
PostPosted: Mon Mar 01, 2010 2:39 am
Thanks for the input. Trying to find out how many more parts I need(carb, exhaust, linkage) to get this working and keep my outlay down. I think with some good pics, we can fabricate the linkage since I manage a machine shop. Once again, thanks.
PostPosted: Mon Mar 01, 2010 7:31 am
See this post. If you've got a machine shop, you needn't even buy a 2bbl intake; you can readily modify your 1bbl intake, which in turn makes the linkage easier and eliminates the need for a shorter throttle cable, and allows you to put a plenum divider in the intake.
PostPosted: Mon Mar 01, 2010 9:27 am
Guess who comes through again? Dan thank you for the fine advice. Being someone that likes to see my own workmanship in things, I love that idea. I thought about an adapter plate but wondered if I would have any serious flow issues but actually it sounds as good if not better with all the other issues that I would avoid.
PostPosted: Mon Mar 01, 2010 10:11 am
I made my own two barrel intake out of a one barrel intake and there is one important issue- the area of the carb mounting portion of the manifold. The carb mounting area on the one barrel intake manifold is *barely* wide enough to fit a two barrel carb (even the "small" two barrels such as the Carter BBD or Holley 2280) when the carb is mounted in the factory perpendicular fashion. When I modified a one barrel intake, I put the carb in the standard perpendicular fashion and I barely had enough room to clear the inboard manifold stud. It actually protruded slightly into the area below the throttle bore of the carb. Mounting the carb parallel to the motor would solve this problem.
PostPosted: Mon Mar 01, 2010 11:02 am
When I did mine I machined the stock manifold flat, so the Holley 2bbl plate would sit flat. The carb is mounted sideways.
PS: this combo ran quicker then an Clifford manifold with a 2bbl adapter plate. Granted, I didn't try rejetting the carb, just a bolt for bolt change.
PostPosted: Mon Mar 01, 2010 11:45 am
I ground the pad flat with a hand-held grinder. I'm sure getting it machined properly is better. Interesting that it worked better than Clifford's! I would be interested to see how a modified stock intake with a plenum divider would do.
PostPosted: Mon Mar 01, 2010 1:02 pm
Carb's not supposed to sit flat. It's supposed to sit tilted towards the front, 'cause as installed, the manifold is tilted towards the back. Measure the factory tilt of the 1bbl mounting pad, write it down, and set up the 2bbl mounting pad at the same angle.
PostPosted: Mon Mar 01, 2010 3:27 pm
I said "flat", not "Level". :P A carb will not necessarily be level on the manifold (it should be level on the car, as installed),
PostPosted: Mon Mar 01, 2010 3:33 pm
Good point! :cool:
PostPosted: Mon Mar 01, 2010 3:47 pm
I said flat, and I meant level! :wink: I didn't do a very accurate or thorough job building my intake, and if I did it again I would be much more accurate. Listen to Charlie and Dan, not me!
