It is currently Thu Jul 16, 2026 12:22 am
Post new topic  Reply to topic  [ 296 posts ]  Go to page Previous 112 13 14 15 1620 Next
PostPosted: Mon Feb 22, 2010 7:16 pm
:shock: Time for a skid-plate! :D
It has crossed my mind. It sits the same height as the muffler so it should be OK.
10.74 @ 127.47 mph 1320 ft
6.65 @ 107.80 mph 660 ft
http://www.youtube.com/c/turbo66valiant
Follow on Instagram - turbo66valiant
Facebook - https://www.facebook.com/ryan.peterson.737
PostPosted: Mon Feb 22, 2010 7:37 pm
Yeah, on level ground it does. Kills the approach angle though.
PostPosted: Mon Feb 22, 2010 8:16 pm
Yep, it will suck but my trailer has a low approach angle so not to worried.
PostPosted: Tue Feb 23, 2010 8:51 am
sorry if i missed it. but what sort of RPM's
through the traps.
I read last night on ALLPAR back in the day a stock 170 would wine to 6500 RMP using a 3 speed and the man stated there was more to go..that's impressive in those days.
slant six's RULE!
http://www.usajon.com
PostPosted: Tue Feb 23, 2010 7:22 pm
This one only spins at 5200. Later
PostPosted: Sun Feb 28, 2010 8:28 pm
I got a few things done today. Main studs are in, o-ringed the block, degreed cam in at 109*, checked cam and bearing wear, trimmed copper head gasket. Ready for the head and possible new exhaust. We'll see. Isky o-ring tool worked nice.
PostPosted: Mon Mar 01, 2010 6:56 am
Sweet!
11.02 @ 120.56
Chassis dyno
PostPosted: Mon Mar 01, 2010 2:16 pm
Does the iksy O ring tool Work with the pistons in place?
I would imagine it would be a chore to keep the chips out of the ring pack?
Lookin Good!
PostPosted: Mon Mar 01, 2010 2:37 pm
Oily/greasy rags and vacuums are your friends. Can't tell you how many holes I've drilled and bore notches I've made with everything assembled. My favorite was drilling a new hole in a spun rear cam bearing with the motor in the car and just the head off. No problems...
PostPosted: Mon Mar 01, 2010 5:10 pm
A shop vac is your best friend. I did the Isly o-ring in car as well. Like Lou said....plug everything up that you can and then vac away!!!...If you have a helper they could vac while you cut away.
I've port matched in the car this way too.
11.02 @ 120.56
Chassis dyno
PostPosted: Mon Mar 01, 2010 8:17 pm
Sweet! I gots me a couple of questions about the pics tho.
What is the black circle in the center of the pistons?
What is the last picture showing, Main clearance?
PostPosted: Mon Mar 01, 2010 9:13 pm
Not for certain what the machined holes are in the center of the pistons. Never seen them before on any others. They are standard TRW's. Anyone know? I guess I should have figured this out before I started using them.
Yes to the main clearance. All four were the same.
Later
Ryan
PostPosted: Wed Mar 03, 2010 8:50 pm
Just a few pics of the current combo outside the car. Mocked up for pics. Later
PostPosted: Thu Mar 04, 2010 5:27 am
Looks Great Ryan. Looking forward to meeting you in Kearney this year.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Thu Mar 04, 2010 5:40 am
:twisted: well now that i managed to pick my lower lip off the floor and clean the slobber off. all i can say is wow! i think i just came out of the na closet! thanks for showing me the light and for turning me to the dark side!!
Image75 dart custom, 225, >10.5-1, hurricane, 500holley, erson cam, 904, 8.8 ford 3.55 or 3.91 aussielocked, 17" steelies, and much more.
