It is currently Sat Nov 14, 2026 5:13 am
PostPosted: Sat Feb 20, 2010 5:57 am
Hi y'all, the end of my antenna cable has split and is now loose, and I can't pull in any radio stations hardly because of it. I tried pulling the whole end piece apart with a pliers and redoing the end but the single wire in the middle only slides back into the very end of the plug without having a way to solidly hold it there. Now I'm only pulling in about one station at a time. Is there any place I could buy new ends to completely remake the end or is there something I could buy to splice a new end from a different vehicle in? Possibly opening up the ability to use different radios from different makes of cars? (I kind of miss having my tunes)
PostPosted: Sat Feb 20, 2010 6:35 am
The antenna cable end is a universal type. Probably best to go ahead and put in a new antenna.
PostPosted: Sun Feb 21, 2010 6:19 pm
For financial reasons I would like to just fix the end on the co-ax cable I have. Is there anywhere I could find splices or new ends to rebuild the plug in?
PostPosted: Mon Feb 22, 2010 2:49 pm
You might try radio shack or a electronics store. If its standard cable.
85 d-100 HEI 2BBl
06 Toyota Corrola
PostPosted: Sat Mar 06, 2010 6:06 am
Would a splice from tv coax cable work on this type of cable? or is it completely different?
PostPosted: Sat Mar 06, 2010 6:12 am
It will work if put in properly. Still better to replace the antenna coax and all.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Sun Mar 07, 2010 6:39 pm
TV cable is not even close to the Antenna cable. I know they "look alike" but the cables impedance is very different. Radio Shack use to sell the end piece-it is called a Motorola plug (male). You can get it off of almost any car built- with more wire attached so it will be easy to splice it.
Lynn
