It is currently Tue May 19, 2026 9:39 pm
PostPosted: Thu Mar 11, 2010 2:07 pm
Does anybody that is using a Weber 38DGES carb on their slant have any pics that I can look at?
I would like to see the adapter that another slanter has used, and also the linkage.
Thanks!!! :)
'78 Volare 225
'67 Charger 318
PostPosted: Thu Mar 11, 2010 2:40 pm
Wes,
Just tried sending you pictures.....got this note back.
Delivery has failed to these recipients or distribution lists:
wesley.moeller@hp.com
The recipient's e-mail address was not found in the recipient's e-mail system. Microsoft Exchange will not try to redeliver this message for you. Please check the e-mail address and try resending this message, or provide the following diagnostic text to your system administrator.
The following organization rejected your message: smtp.hp.com.
PostPosted: Thu Mar 11, 2010 2:45 pm
1/2" alum plate, drilled carb mount holes one size up to fit 2bbl intake studs, drilled and recessed bolt for inside plate to intake holes, tapped holes for back studs for carb, as far as linkage I made a tab mounted off of egr bolt two holes (throttle & kickdown) , bent and welded orig linkage on carb oused two ball fittings
'72 4 dr Dart
'63 4 dr Dart
PostPosted: Thu Mar 11, 2010 8:03 pm
Thanks for the responses guys!
I guess I need to change that in my profile, I got laid off from HP in 2003! :shock:
Here ya go Ted, and anybody else:
Wesola78@yahoo.com
Thanks!
'78 Volare 225
'67 Charger 318
PostPosted: Thu Mar 11, 2010 9:41 pm
Email with pictures re-sent!
PostPosted: Thu Dec 30, 2010 10:17 am
Okay, I finally had a couple of days off from BOTH jobs, and the new Weber 38DGES is bolted onto my Offy intake. Long story short, it runs!
I still have to reconfigure/modify my throttle linkage and Lokar kickdown linkage, but I'm impressed with how my slant runs. 8)
Gotta go to work now, more updates later.
'78 Volare 225
'67 Charger 318
Users browsing this forum: Google [Bot] and 13 guests
