It is currently Wed Sep 30, 2026 10:59 pm
Post new topic  Reply to topic  [ 521 posts ]  Go to page Previous 1 … 7 8 9 10 11 … 35 Next
PostPosted: Mon Feb 22, 2010 6:59 pm
I have a question, can the coil bracket/module be bolted in the stock location for the coil? or would it get to hot? I want to keep it on the engine so the high voltage will have a solid path back to the coil.
thanks for any advice
85 d-100 HEI 2BBl
06 Toyota Corrola
PostPosted: Mon Feb 22, 2010 7:14 pm
6 Pack Dart
Why clutter your area to work around the changing of sparkplugs. The ground strap or if you have the ground lead from the battery attached to the block would be quite good.
PostPosted: Tue Feb 23, 2010 1:17 pm
Just wonderning. I want to make it as easy on the coil as possible.
85 d-100 HEI 2BBl
06 Toyota Corrola
PostPosted: Tue Feb 23, 2010 1:26 pm
On my brother's 83 Dodge van, I installed an e-core coil off of a fuel injected 89 Ford 351 motor. I was able to use the bracket that came with the coil to mount it onto the two factory coil mounting bolt holes on the slant six alternator bracket. I enlarged one of the e-core bracket holes to make it fit, but it fit very well. However, this was on a van. In an a-body you might have clearance issues with the passenger fenderwell. Also, Ford used numerous different e-core coil brackets depending on the application. I am fairly certain that all Ford truck/van fuel injected motors use the right coil bracket. I do know that the mustang bracket is different.
PostPosted: Tue Feb 23, 2010 2:59 pm
thanks Reed
Did you use a GM type module with a ford coil?
85 d-100 HEI 2BBl
06 Toyota Corrola
PostPosted: Tue Feb 23, 2010 4:41 pm
At this point, my brother's van is still running Mopar electronic ignition. HEI will be added in the future, but it isn't on there yet.
PostPosted: Tue Feb 23, 2010 6:28 pm
OK, I guess that a coil,is a coil, is a coil so long as its a E-core coil...........right?
thanks again Reed
85 d-100 HEI 2BBl
06 Toyota Corrola
PostPosted: Tue Feb 23, 2010 7:17 pm
HEI works with standard coils, but I use an E-core GM coil myself.
PostPosted: Tue Feb 23, 2010 7:38 pm
Within the next month or so, I will be pulling the head on my brother's to replace it with a rebuilt one. I'll try and remember to snap some pictures of the coil mounting setup at that time.
My point was just that it is possible to mount an e-core coil to the factory slant six spot using the Ford truck/van coil and bracket.
PostPosted: Thu Apr 01, 2010 5:55 pm
Car Model: 1964 Valiant Sedan
I am starting this conversion and need a bit of help with the coil wiring. I have the 3-pin gm coil. (Picture from Dan's write-up. Thanks for revamping that, btw.)
Everyone else seems to be using the 4 pin version. The coil has no markings as to what's what, so I have no idea which pin is A and which is C. (I figured out B on my own. :) ) Thanks in advance.
64 Valiant
PostPosted: Thu Apr 01, 2010 6:58 pm
6 Pack Dart
As you have positioned in picture left is A and right is C.
You will be better off using the older 4 pin module, you will have to trim off the fin closest to back side of the module to get it to fit. Side note the connector for the coil is not generally at parts stores (hope you got it with the rest of this unit) if not PM me for the part #
PostPosted: Thu Apr 01, 2010 9:26 pm
Thanks for clearing that up. I have a new connector for it so I think all I have left is to wire it up.
64 Valiant
PostPosted: Fri Apr 02, 2010 8:48 pm
Take a look at the updates in the original thread HEI Electronic Ignition Retrofit How-To. You'll find that and others (including this thread) in the engine FAQ under Electrical FAQ-More Ignition information.
Ceej (and probably others too) has done a great job updating the FAQ. :bow: :D
Olaf.
Aspenized
PostPosted: Wed Apr 14, 2010 3:06 am
I have also a question about the coil. I'm collecting items for the conversion, and already found a electronic distributor and a HEI unit, but i don't know which coil i need.
If I search for the FD-478, I only find coils with 3 pins like the one in the how-to, but in the HEI wiring diagram there are 4 pins. Can anybody tell me which coil I should use?
Many thanks,
Willard
PostPosted: Wed Apr 14, 2010 8:05 am
6 Pack Dart
Either coil will work, kind of what do you have. The 4 pin coil conecters are available at auto parts stores as "coil pig tails" and are a 2 part unit, 1 light and other dark.
