It is currently Sat Jun 13, 2026 2:21 pm
 Post subject: Cragar rims
PostPosted: Sun Apr 18, 2010 6:19 am
I am considering a new set of Cragar rims for the Valiant - I have run on a used set for years now and although one rim has always given me trouble ( have to keep it on the back) I have never noticed any other issues.
Just to be on the safe side I thought I'd ask if anyone has purchased a set in the past 2 or 3 years.
Specifically I am looking at the Cragar S/S (part# 08070) rim - 14" x 7" with a 5 x 4" stud pattern and 4.125 backspacing - I will be putting P185/70R14 tires on them.
So if anyone has feed back it would be appreciated.
Also if anyone can point me to a site that sells Cragar rims with tires - balanced and shipped to your door that would rock - I had a site a few years back but I cannot seem to find it.
Thanks all :)
Peace
The car I am restoring is a 1971 Valiant 4 door with a slant 6 - 225 engine.
PostPosted: Sun Apr 18, 2010 11:21 am
Why such a narrow tire on a 7" wide wheel? You can put 225 or 235mm section width tires on a 7" wheel easily. If you are intent on running a narrow tire like that I'd use 6" wheels and loose some weight.
PostPosted: Sun Apr 18, 2010 1:06 pm
That us what I have on the wheels I am running atm - I know nothing about tires sadly. I would love a wide tire on the car although I be cautious at the front for clearance.
Is anyone else running 225 or 235 tires on the front of their 71 Valiant on a 14" x 7" rim?
PostPosted: Sun Apr 18, 2010 2:08 pm
A 215/60 or 205/65 would be perfect on a 7" rim..........
 Post subject: Re: Cragar rims
PostPosted: Fri Apr 30, 2010 3:25 pm
Thanks all :)
Peace
I think Tire Rack will ship balanced and mounted. Don't know if they carry the Cragar's, though.
My 73 Dart /6 has 205/60-15s on a 7" wide rim with 4¼" back space. No problems with fit.
You can't fix stupid. - Ron White
PostPosted: Sat May 01, 2010 8:20 am
Check Summit. www.summitracing.com
yep. browsing my last catalog shows that wheel for 149.95 and if you order tires balancing is 15 per wheel. BF goodrich radial ta for 85.95 or cooper cobras for 88.95, both in a 215/70. total cost is about $1010 plus shipping depending on any promos.
72 dart acquired 12/08 /6,holley2b, mopar perf intake, mopar perf header, cam, built motor,904 finally re-installed, 8.75....still needs sorting out.
99 dakota 318 5 speed reg cab picked up 9/09; Trans finally fixed! woohoo!
PostPosted: Tue May 04, 2010 1:37 pm
Both my brother's '67 Barracuda and my '72 Swinger run 235/60-14's on the front with no rubbing. Both are disc brake cars.
vm
