It is currently Sat Nov 14, 2026 1:21 am
PostPosted: Wed May 12, 2010 6:44 am
Question:
Mid-80s Mopar electronic ignition uses a ballast resistor. Has anyone replaced the resistor AND the coil with a true, 12 volt coil? If so, has this worked out okay (no coil or ECM burnout issues)?
Thanks!
Jeff
PostPosted: Wed May 26, 2010 8:52 am
Not quit sure what your asking.....
However, I have tossed the resistor so the system gets a full 12-15 volts all the time and replaced the coil with a Pertronix 12 volt 3 ohm coil.
The system works great! I am running a older MOPAR orange ECU.
PostPosted: Wed May 26, 2010 12:55 pm
That's exactly what I needed to know!
Thanks!
Jeff
