It is currently Sun Dec 28, 2025 1:31 pm
 Post subject: throttel cable
PostPosted: Sun May 16, 2010 10:09 am
i am done with my 2bbl conversion,its a parallel holley 2280 and it runs great. The one issue is with my throttle cable its short. Does anyone know where i can get a new cable of the proper length?
85 d-100 HEI 2BBl
06 Toyota Corrola
PostPosted: Sun May 16, 2010 11:00 am
How long is your present cable? Care to show us some photos?
PostPosted: Sun May 16, 2010 5:15 pm
Dan i'm not sure of the length. I have a working throttle cable but it sticks once in a while and I don't like that at all. Hear is a link to photobucket i hope it works [url=http://s983.photobucket.com/albums/ae319/carlaherrnstein/]
85 d-100 HEI 2BBl
06 Toyota Corrola
PostPosted: Sun May 16, 2010 5:24 pm
crap :!: lets try that once more
pics
85 d-100 HEI 2BBl
06 Toyota Corrola
PostPosted: Sun May 16, 2010 5:30 pm
Cable doesn't look too short, but also doesn't look like a throttle cable. Looks like maybe a bicycle cable? Can't tell. Is the end piece screwed solidly to the carburetor throttle lever, or can it pivot? It needs to be able to pivot or you can get binding.
PostPosted: Sun May 16, 2010 5:59 pm
Well.. thats a choke cable that I modified, it works but, it sticks open. The OEM cable was short. The cable end is able to pivot freely it seems to be binding in the cable, I lubed it with STP that did help.
85 d-100 HEI 2BBl
06 Toyota Corrola
Last edited by carlherrnstein on Sun May 16, 2010 8:20 pm, edited 1 time in total.
PostPosted: Sun May 16, 2010 6:18 pm
Choke cable is neither adequate nor safe as a throttle cable.
PostPosted: Sun May 16, 2010 8:02 pm
I know that now, as it isn't working right. I am trying to find a shop that can make a cable for me or can sell me a compleat assembly that is the proper length that is both adequate and safe.
85 d-100 HEI 2BBl
06 Toyota Corrola
PostPosted: Sun May 16, 2010 9:49 pm
6 Pack Dart
Iry a motorcycle shop, they can build you a safe and good cable.
 Post subject: throttle cable
PostPosted: Mon May 17, 2010 4:59 am
another option is to buy off E-bay or Summit has some great cables (brand name " Lokar ". That are fully adj and smooth.
regards
max
1966 barracuda 360
1964 signet conv. 170 turbo
Bonneville or Bust 2012
PostPosted: Mon May 17, 2010 7:11 am
Im using a go cart cable from here. http://www.gokartsupply.com/thcable.htm Of course this is in a van, so I need a loooooooong one.
PostPosted: Mon May 17, 2010 9:49 am
Some of the carbureted front wheel drive throttle cables out of 2.2 K cars & vans are longer, and 2.6 still even longer. I think Rock Auto lists cable length of these cables. These cables can be fitted to our slant cars and made to work with little effort by adjusting the grommet that pass through the bulkhead.
PostPosted: Tue May 18, 2010 11:30 am
Thanks for all the great advice. :D
85 d-100 HEI 2BBl
06 Toyota Corrola
PostPosted: Fri May 21, 2010 9:58 am
I went to a motorcycle shop and got a used used cable from a japanese bike for $3.50. I had to cut it and fit it but it works smooth and freely with no binding or sticking.
Thanks for the help agin.
85 d-100 HEI 2BBl
06 Toyota Corrola
