It is currently Fri Jun 05, 2026 3:59 pm
Post new topic  Reply to topic  [ 23 posts ]  Go to page Previous 1 2
PostPosted: Fri May 14, 2010 8:13 pm
No modern rear disc setup swaps over directly to a Mopar rear end. There are some various hack approaches that people use but nothing is really clean.
Best kit I've seen so far is the one that DoctorDiff sells. He uses Mustang calipers, Toyota rotors and a CNC machined bracket to hang it all together. His kit keeps the tapered roller bearings in the axle which is a big plus. Lots of other kits force you to swap in the Green ball bearings.
I think the Baer kit is also pretty good and Eberg likes the SSBC kit but for my money I'd go with DoctorDiff's.
PostPosted: Sat May 15, 2010 5:07 am
Thanks for chiming in, Andy.
FWIW, the tsm-mfg.com kit keeps the tapered roller bearings, so no issues there.
PostPosted: Mon May 17, 2010 7:52 am
The Jeep swap within the link I posted doesn't sound like a "Hack job", and has minimal mods. I haven't done it but it looks rather simple. Am I missing something?
PostPosted: Mon May 17, 2010 8:51 am
Andy,
I would be interested in what criteria you consider to give a "clean" brake swap that is not a hack job.
PostPosted: Mon May 17, 2010 11:37 am
I'm guessing Andy would have no appreciation for the models I built as a kid. Isn't that the fun of working on cars as an adult?
,Cliff
'72 4 dr Dart
'63 4 dr Dart
PostPosted: Mon May 17, 2010 11:58 am
Andy probably built models as a kid too. He is an unusually creative and competent guy, so I am genuinely interested in his thoughts. That said, I have a kit on my car that works very well for me that he did not think was "clean." Hopefully he will chime in here with some wisdom.
I am a bit more fast and loose than Andy is, and it has worked for me (and been fun). Still, there is always more to learn from those with more experience...
Cheers,
PostPosted: Thu May 20, 2010 5:44 pm
I tried this swap in a boneyard, see here http://www.moparstyle.com/forums/f-j-m- ... p-out.html and please read the whole thing lot of good info with just a bit of R&D by yours truly,
-Mike
I am the Guardian, I hate helos, everything leaks.......
PostPosted: Thu May 20, 2010 5:52 pm
Thanks for more great info Mike...
,Cliff
'72 4 dr Dart
'63 4 dr Dart
