It is currently Tue May 26, 2026 9:18 am
 Post subject: power steering
PostPosted: Tue May 25, 2010 5:14 pm
a fellow slantsixer came by today and has a 64 slantsix valiant with manual steering , he wants power steering , all the parts i have are from 67 to 76 . does anybody know if it possible to swap these parts into a 64?
PostPosted: Tue May 25, 2010 5:49 pm
He'll need at a minimum the center shaft from a PS-equipped 64-66. Might be easier to find a complete column though.
47 Dodge Custom 4 Door sedan
87 D100 Short Bed slant 6
Retired USAF 1966-1986
PostPosted: Tue May 25, 2010 5:53 pm
6 Pack Dart
Isn't there a difference in the pitman arm ??
PostPosted: Tue May 25, 2010 6:59 pm
Yes, the pitman arm is '62-'66 only.
Steering box is '62-'72 A/B-body
Steering column or steering shaft will need changed (shorter)
P/S pump and brackets from '67-up cars do not necessarily fit easily in '66-down cars -- they'll bolt up to the engine just fine, but may not leave enough room for P/S belt adjustment without hitting the inner body metal.
PostPosted: Wed May 26, 2010 4:02 am
so will the pitman arm of the standard box from the 64 fit the power steering box from 67 to 76, are the splines the same?
PostPosted: Wed May 26, 2010 9:38 am
Again: Steering box is '62-'72, A/B-body. You cannot use a '73-up power steering box, which will not connect to the '62-'66 pitman arm.
PostPosted: Thu Jul 15, 2010 1:30 pm
Sorry to bring back a old topic but got a question in this matter, I got a 71 Duster and got everything but the steering column or steering shaft from a 75 Duster to get power steering.
The power steering box will fit and install without problems?, will I need other thing to modify appart the steering column and/or steering shaft?
Thanks in advance!
Mopar Muscle is well defend by Slant Six!
Valiant Duster 1971
PostPosted: Thu Jul 15, 2010 1:42 pm
If you're using parts from a '75 on your '71 you'll need to transplant the steering box, pitman arm, idler arm and center link. You'll also need a steering column or the shorter shaft used with power steering.
