It is currently Wed Jun 03, 2026 12:11 pm
 Post subject: Shackle Collar Bracket?
PostPosted: Sun May 30, 2010 9:20 pm
Car Model: 1969 Plymouth Valiant 225 \6
My mechanic said my shackle collar bracket is rusting apart on my right rear suspension. Anyone know where I might find one of these? Thanks.
PostPosted: Mon May 31, 2010 4:48 am
If you mean the section of frame that the upper shackle bolt passes through, look [url=http://www.yearone.com/pco/1_0210/full.asp?page=543] here[/url] for a photo and repair part most likely manufactured by; “Safe-T-Capâ€￾. Check other venders for best price.
PostPosted: Mon May 31, 2010 2:34 pm
By the looks of the pictures, I'm thinking the rear shock mount. All I know is he said shackle collar bracket or something to that effect. I'll clarify with him to make sure. Thanks for the site info.
 Post subject: Shackle collar bracket
PostPosted: Mon May 31, 2010 10:32 pm
I'm not sure if it is the right name, but the shackle only touches two things-the spring's rear eye and a bracket that bolts to the car. This bracket is bolted up to a boxed section on the rear outboard frame area by two 3/8 coarse bolts and has a tube section between two abbreviated triangles.
Either the bracket or the frame section could be the problem but I think that's definitely what his mechanic is talking about. Mine are spaced out a little to get a good shackle angle.
madam im adam
PostPosted: Mon May 31, 2010 10:38 pm
Oh and I got extras before by posting on here and moparts and bigblockdart and forabodiesonly and stuff like that. A new part could easily be made from the old one for not that much money or time if you are skilled or know a weldor.
Good luck[/img]
madam im adam
PostPosted: Tue Jun 01, 2010 6:14 am
True, one can make a patch for the perch for less. However, if that section of the frame is rusted to the point the bolt is no longer held in its proper location, the surrounding material in that section of frame is most likely weak some distance away from the visible problem area.
The reason I like these “Safe-T-Capsâ€￾ is this [url=http://www.autorust.com/safetcap.html] outfit[/url] has fixed a million more old rusty Mopars & other old heaps than I have ever seen in the last forty years, and know from experience how far away from a rusted-out area one generally needs to go the make a strong, safe, with properly located attachment points, long lasting repair. To me it is money well spent to take advantage someone else’s experience & expertise.
This area of the frame experiences a complicated set of dynamic forces being exerted while under way, and must be strong to resist these forces. If the shackle is not located precisely in relation to its opposite twin on the other side of the car you will experience drivability quirks. If a repair is not strong enough, one will be under the car repairing the repair, which can make a still bigger mess of things…
