It is currently Sat Jun 06, 2026 8:04 am
PostPosted: Sun Jun 13, 2010 1:37 pm
Well pics are worth a thousand words, bottom I brought the motor to TDC, installed degree wheel, zero'ed it out and turned it by hand (read breaker bar and a 1 5/16th socket thank you Mopar big block for the donation (oil slinger, crank bolt and washer)) brought slightly ahead at 250degs if I am reading it right instead of the recommeded 240degs. but when I bring it to 240degs, its only at 0.044 lift, so obviously its only a tooth off, gonna have to say cam gear,
can I leave it or do I have to adjust btw cam specs are 270in 280ex 112deg LSA 240in/250ex @ .050 lift
-Mike
I am the Guardian, I hate helos, everything leaks.......
PostPosted: Sun Jun 13, 2010 3:20 pm
so I have given up on this, cam degreeing makes no &#@% sense, unless I am over analyzing the $#!+ out of this, hell I don't even know if I am reading the degree wheel right, anyone wanna help ?? anyone got any vids on how to do this ??
-Mike
 Post subject: try this.....
PostPosted: Sun Jun 13, 2010 3:43 pm
It can be very frustrating at first
look here
..............................best regards and hope it works for you max
http://www.google.com/search?q=camshaft ... qwQwAw[url]
1966 barracuda 360
1964 signet conv. 170 turbo
Bonneville or Bust 2012
 Post subject: degreeing
PostPosted: Sun Jun 13, 2010 3:47 pm
BTW you ARE over analyzing ..............take a deep breath ....then call it every name you can think of .........THEN START OVER :D :D :D :D :D
1966 barracuda 360
PostPosted: Sun Jun 13, 2010 4:03 pm
so you crank it all the way over till the intake is fully open....zero the dial... measure .050 before and after max lift add the 2 then divide in half to get installed centerline.......right ???????
-Mike
BTW MAD PROPS TO YOU MAX !!!!
PostPosted: Sun Jun 13, 2010 4:20 pm
ok so I got 152 and 63 (did it backwards but ok) added together it equals 215 divided by 2 equals 107.5degs installed center line. the LSA on this cam is 110deg (turbo cam) intake lobe is 106 ( i assume installed centerline) , but then again I never got a cam card with the cam (since I didn't know it was supposed to come with one, 1st cam purchase),
So am I off a tooth for 1.5 deg's ?? or can i run as is ??
-Mike
PostPosted: Sun Jun 13, 2010 5:13 pm
Degreeing is first step is finding the difference of two readings (one reading on the dial then other way on new dial reading). Add up and split it for new degrees, then move pointer to that, that's your zero setting. of your crankshaft first with hard stop piston. Then determine your centerline of your camshaft based on crankshaft.
I may not make sense but I'm tired.
Cheers, Wizard
 Post subject: cam
1 degree or so doesn't matter much..........If you're sure you did it right (sounds like you did) I'd run it....................wouldn't bother me at all. But you may want a second opinion. but sounds like you have it down pat.
regards..............max
1966 barracuda 360
PostPosted: Sun Jun 13, 2010 5:55 pm
From your description I believe you are finding the intake centerline just fine. 107.5° is too far retarded. I'd run that cam about 102° ATDC intake centerline.
PostPosted: Sun Jun 13, 2010 7:12 pm
cam card says 106deg installed (see above image) ^^^^^^^, Josh how would I advance (?) the cam to 102* ATDC, and what benefits would there be to doing so ??
-Mike
PostPosted: Sun Jun 13, 2010 9:29 pm
It's easiest to change the installed centerline with an offset bushing in the dowel pin hole. Mr. Gasket makes the kit andSummit Racing sells them. With the cam advanced you will get more low end and mid-range torque with little, if any loss on the top end. The car will be quicker and more fun to drive.
PostPosted: Mon Jun 14, 2010 4:57 pm
thats what this is for.......
-Mike
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 4 guests
