It is currently Thu Oct 08, 2026 11:45 am
 Post subject: Diff Question.
PostPosted: Wed Jun 16, 2010 11:00 pm
So found out I can get 4.11 diff gears (or it was 4.55 not entirely sure). for around $300 and I was told that i can just swap them straight into what i already have.
I have a 1967 VC Val and it's stock as far as the diff is concerned. can I just swap this new ring and pinion in?
And the other big question is
Is this still street able? Or will I find it to jerky and bad with acceleration...?
Thanks a lot I am still pretty new to this stuff!
PostPosted: Wed Jun 16, 2010 11:09 pm
6 Pack Dart
4.11 will not be fun for road speeds due to higher engine RPM's, 4.55's much worse.
What size (type) of rear axle housing?
 Post subject: Lol...
PostPosted: Thu Jun 17, 2010 5:29 am
Only if you have an automatic or 3 speed...it isn't bad if you are using an overdrive transmission... :wink:
PostPosted: Thu Jun 17, 2010 5:52 am
Ok, Sorry massive newbie at this.
So I think I've got this right;
Is it the engine rotates 4.11 times every wheel revolution?
Meaning Higher RPM and more acceleration.
However a lower gear means better top end (Not exactly sure what this means) and slower acceleration but higher speed?
So then having a higher ratio (for a streeter car) will mean I have a higher RPM all of the time?
PostPosted: Thu Jun 17, 2010 5:53 am
just to add yeah I have the 3 speed auto 904tf
PostPosted: Thu Jun 17, 2010 7:24 am
6 Pack Dart
Yes, the number of engine RPM's to wheel RPM's are what the numbers indicate. The closer you get to 1 to 1 the more it is like starting out like you had a stick shift and left it in high gear.
Users browsing this forum: No registered users and 16 guests
