It is currently Fri Jul 17, 2026 11:17 pm
Post new topic  Reply to topic  [ 33 posts ]  Go to page 1 2 3 Next
PostPosted: Thu Jul 08, 2010 11:46 am
Running 5000rpm through the traps with these runs!! Stock bore 225.
Best time 60' time is 2.0 My HP computed from my 60 Foot Time of 2.0 at Weight of 3400lbs with me in the car. 187.05 HP. Looks good here!
Best 1/8 mile time is 10.0 My HP computed from my ET is 154.87 rear wheel HP and flywheel 172.08 HP. Loss of 15hp?
Best 1/4 mile time is 16.27 My HP computed from my ET is 140.43 rear wheel HP and flywheel 156.03 HP. Loss of 15hp more?
Around 30 HP loss, seems like to much. Is this normal? Why is this? What can we do to correct this?
'72 Image Duster /6 with turbo build up
'03 Ram 2500 4x4 w/HEMI 5sp 4:10 posi
My Twister Page
PostPosted: Thu Jul 08, 2010 12:20 pm
Probably too much mechanical advance in the distributor. What's the total mechanical timing and the RPM where it's all-in?
PostPosted: Thu Jul 08, 2010 12:24 pm
Around 26 fixed Joshua :)
My Twister Page
PostPosted: Thu Jul 08, 2010 2:04 pm
You mean you have no mechanical advance in the distributor?
PostPosted: Thu Jul 08, 2010 2:25 pm
Automatic or manual transmission?
If auto, you're getting torque multiplication, which will inflate the power numbers in the shorter distances..........
PostPosted: Thu Jul 08, 2010 2:41 pm
None that I can see.
My Twister Page
PostPosted: Thu Jul 08, 2010 2:42 pm
Automatic. I see like my truck has more power in low gear. Gear to weight ratio. Pulls the weight better in low, than in high, Thanks.
My Twister Page
Last edited by Mister Twister on Thu Jul 08, 2010 4:40 pm, edited 1 time in total.
PostPosted: Thu Jul 08, 2010 3:07 pm
The only slant six distributors without a mechanical advance are for Lean-Burn and those don't have a vacuum advance either. If your initial timing is 26° BTDC the timing is too far advanced.
PostPosted: Thu Jul 08, 2010 3:38 pm
Could be cam is too far advanced too. What is converter stall speed?
PostPosted: Thu Jul 08, 2010 4:18 pm
I don't know what the distributor came out of. It was missing a spring, not the heavy duty one. Installed a light duty spring there. #925B from a Mr.Gasket kit
My Twister Page
PostPosted: Thu Jul 08, 2010 4:31 pm
The cam installed straight up they said when I bought the motor, it was already put together.
It has a 3200 10" converter. Sits @ 3000 when staged.
My Twister Page
PostPosted: Thu Jul 08, 2010 4:43 pm
Don't put too much faith in those calculators. All they are is a scale of how much HP it takes to move X weight X distance in X time. They do not take into consideration thiongs like aerdynamic drag, gearing, etc..
PostPosted: Thu Jul 08, 2010 6:01 pm
I agree with Zilla.The Wallace calculator says my car has 395 rwhp and will do 10.83 calculated from my 60 ft time.I am actually right around 300 rwhp and the car is capable of high 11s.My goal is 11.66 all motor.Guzzi Mark
PostPosted: Thu Jul 08, 2010 6:21 pm
It reads like you're getting wheel spin at half track. That 10 sec 1/8 ET should be good for a 15.7 1/4 mile
What mph are you running. You're better off using mph to calculate HP.
Which 1/4 mile HP calc are you using. The one I use puts your rwhp at 156.3 from your 1/4 ET. There you go, you just gained some HP right there.
:D
62 Valiant, 225cid Slant 6/PB 904 with lots of good bits
http://www.moparmarket.com/readersrides ... user=SV162
PostPosted: Thu Jul 08, 2010 9:11 pm
From what I'm reading, you have a mechanical advance with very light springs that come all in at idle?
