It is currently Thu Oct 31, 2024 2:37 pm
 Post subject: Long rod 225 buildup
PostPosted: Sun Jul 20, 2003 11:33 am
I've reached a point in my long rod buildup that brings me to a question. The issue at hand is the compression ratio. I'm at approx 9:1 now, but if I go for a quench setup, it'll put me at right around 10.5:1. Given that this is going in a daily driven street car, with EFI and a 4 speed, I'm a bit torn. For those of you that have built up the 198/2.2 setup in the past, just how much compression will it handle on the street, before pump gas becomes a major issue?
FYI, the current buildup looks like this:
76 225 block
Forged crank (0.000/0.010)
198 rods
KB 2.2 turbo pistons (+18cc Dish)
Double roller timing set
Stand pipes in the lifter Valley
76 Head
Ford 300 valves and seals
Hardened seats
Ported/polished
340 Springs
I'd tell you about the injeciton setup, but I want to keep it under wraps for the time being. :)
Any thoughts on the motor/compression issue?
Brett
1963 Valiant Vert(225 /6)
1964 Dart GT Vert(225 /6)
1965 Dart GT (273)
1966 Barracuda (273)
1966 Dart (225 /6)
1970 Charger R/T (440)
1972 Satellite 4 door (318)
1974 Valiant 4 door (318)
1981 Ramcharger (318)
1987 RamVan (225 /6)
 Post subject: Cool....
PostPosted: Sun Jul 20, 2003 11:46 am
awesome! things are moving forward....
I'll keep my lips zipped on your 'idea', it's really awesome and simple if you can pull it off...it also gives me another thing to look for in the 'other' local yard....
:twisted:
PostPosted: Sun Jul 20, 2003 3:05 pm
What cam are you going to use?
Static compression / cylinder pressure and cam numbers go hand-in-hand.
PostPosted: Sun Jul 20, 2003 3:16 pm
I'm going to order the cam once I've got everything else figured... Match it to the rest of the hardware, as it were.
PostPosted: Tue Jul 22, 2003 6:39 pm
Mine was running at about 11-1 on pump gas. The long rod seems to make the motor very resistant to detonation. I started with a 268*/.460" Racer Brown and ended up with a .528" Mopar cam. :shock:
PostPosted: Tue Jul 22, 2003 8:21 pm
I have 12.5 to 1 in the one I'm building now, running an Isky 505 cam. (.505 lift)
my guess is that it will have 195 psi of cranking cylinder pressure, I plan to run this one on race gas . :twisted:
http://www.dutra.org/pictures/engine/du ... slant6.jpg
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 3 guests
