It is currently Thu Nov 26, 2026 2:17 pm
 Post subject: Long rod 225 buildup
PostPosted: Sun Jul 20, 2003 11:33 am
I've reached a point in my long rod buildup that brings me to a question. The issue at hand is the compression ratio. I'm at approx 9:1 now, but if I go for a quench setup, it'll put me at right around 10.5:1. Given that this is going in a daily driven street car, with EFI and a 4 speed, I'm a bit torn. For those of you that have built up the 198/2.2 setup in the past, just how much compression will it handle on the street, before pump gas becomes a major issue?
FYI, the current buildup looks like this:
76 225 block
Forged crank (0.000/0.010)
198 rods
KB 2.2 turbo pistons (+18cc Dish)
Double roller timing set
Stand pipes in the lifter Valley
76 Head
Ford 300 valves and seals
Hardened seats
Ported/polished
340 Springs
I'd tell you about the injeciton setup, but I want to keep it under wraps for the time being. :)
Any thoughts on the motor/compression issue?
Brett
1963 Valiant Vert(225 /6)
1964 Dart GT Vert(225 /6)
1965 Dart GT (273)
1966 Barracuda (273)
1966 Dart (225 /6)
1970 Charger R/T (440)
1972 Satellite 4 door (318)
1974 Valiant 4 door (318)
1981 Ramcharger (318)
1987 RamVan (225 /6)
 Post subject: D
PostPosted: Sun Jul 20, 2003 11:46 am
D
PostPosted: Sun Jul 20, 2003 3:05 pm
What cam are you going to use?
Static compression / cylinder pressure and cam numbers go hand-in-hand.
PostPosted: Sun Jul 20, 2003 3:16 pm
I'm going to order the cam once I've got everything else figured... Match it to the rest of the hardware, as it were.
PostPosted: Tue Jul 22, 2003 6:39 pm
Mine was running at about 11-1 on pump gas. The long rod seems to make the motor very resistant to detonation. I started with a 268*/.460" Racer Brown and ended up with a .528" Mopar cam. :shock:
PostPosted: Tue Jul 22, 2003 8:21 pm
I have 12.5 to 1 in the one I'm building now, running an Isky 505 cam. (.505 lift)
my guess is that it will have 195 psi of cranking cylinder pressure, I plan to run this one on race gas . :twisted:
http://www.dutra.org/pictures/engine/du ... slant6.jpg
Users browsing this forum: Ahrefs [Bot], Bing [Bot], valiant64 and 11 guests
