It is currently Fri Jun 05, 2026 3:21 am
PostPosted: Wed Jul 21, 2010 12:46 pm
Would one of you please take the time and look at Ebay item 250666924454 and tell me if this appears to be a complete SSix setup? Also does the intake appear to be legit? Looks to me like someone spray painted a steel intake. You can reply to me via Private Message if you would like. Thank you.
PostPosted: Thu Jul 22, 2010 11:29 am
The linkage appears to be complete. The intake may very well be an aluminum super six intake, the 2-piece variety. I have heard that these are notorious for having vacuum leaks. The carb looks like a Carter bbd.
Is it worth it? That's up to you. Personally, I would hold out for an iron super six intake, or get a 1bbl intake and make it into a 2bbl intake.
This is just my two cents.
'78 Volare 225
'67 Charger 318
 Post subject: Intake and Carb
PostPosted: Thu Jul 22, 2010 12:03 pm
Thanks for the info. I am going to take your advice and look for another super six setup, preferably from someone on this site.
PostPosted: Fri Jul 23, 2010 6:06 am
You can get all of the pieces needed for a super six conversion together, but you don't have to. If you have trouble finding the stock kickdown linkage, Lokar makes a nice kickdown cable. Instead of an iron 2bbl intake, you could use an aluminum Offenhauser intake with a 2 to 4bbl adapter, that's what I'm doing. More expensive, but it's nice.
This is just to let you know that you have other options.
'78 Volare 225
'67 Charger 318
Users browsing this forum: Amazon [Bot], Google [Bot] and 3 guests
