It is currently Fri Apr 24, 2026 8:37 am
PostPosted: Wed Jul 02, 2003 10:15 am
Has anyone done this before? What kind of donor car can I get the parts from and what parts do I need?
PostPosted: Sat Jul 05, 2003 12:04 am
There's a kit available from Wilwood that's supposed to be fairly light-weight, but I don't know how much it costs. I'm doing a swap to discs for my 64 valiant right now using all of the suspension and brake bits from a 76 duster. Rather than restating everything I'm doing, you could take a look at what Rob (?) has to say on the subject at http://users.rcn.com/alokaeng/Techhelp. ... and%20Swap He's got a decent write-up of what you'll need.
-Jon
 Post subject: Just like a later Dart.
PostPosted: Sun Jul 06, 2003 2:25 pm
There's several options for this. There's aftermarket kits. There's several different ways of adapting junkyard discs - either the '72-earlier conversion (needs the ball joints and everything in between from a disc car) or the '73-up conversion (same, but also needs the upper control arms). With the '73-up hardware, you will have the large bolt pattern, which allows a wider selection of wheels but means you'll have to swap the rear bolt pattern too. There are a few mix-and-match options using taller F/M/J body spindles or the late '70s B-body 11.75" discs and caliper brackets on post-'73 spindles, too.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Thu Jul 24, 2003 7:45 pm
This may be of interest to someone
http://www.bigblockdart.com/cgi-bigbloc ... 1058137915
PostPosted: Fri Jul 25, 2003 12:02 pm
Think i'll piggyback on this post as iv'e had it with the stock 63 ball joints and tie rods,tired of replacing them every two years and a conversion would be a relief. Guess you can tell what I did on my days off. ...thanks for the information guys...Dave
PostPosted: Fri Jul 25, 2003 2:13 pm
This is an excellent book that pulls together the junkyard approach to doing a disk type conversion.
Performance Handling for Classic Mopars
by Tom Condran
$30.00 - 162 pages
Faster Forge and Press
P.O. Box 282612
San Francisco, CA 94128-2612
http://www.moparpages.com/suspension_book/
PostPosted: Fri Jul 25, 2003 2:59 pm
You should also check out a good brake article ("Disc-o tech"??) at www.moparaction.com
