It is currently Thu May 21, 2026 10:02 pm
 Post subject: Torsion bar question.
PostPosted: Mon Sep 06, 2010 8:54 am
Anyone out there running a 1-inch torsion bar in their A-body with the slant 6? Too big?
SOLD! Went to New Zealand. '64 Valiant Signet 200, 2-dr hardtop. 225/4-speed/Pistol Grip, Offy 2-1bbl, Clifford headers.
Minimum government means maximum LIBERTY!
PostPosted: Mon Sep 06, 2010 10:42 am
1.04" in my '67 Valiant. No problems as long as you have good shocks and the car isn't rusty. I'm running QA1 single adjustable Stocker Star shocks.
PostPosted: Mon Sep 06, 2010 11:59 am
Too big in the world I drive in. Our roads are too rough.
I like a lighter T bar and a big sway bar.
Add the best shock you can afford.
PostPosted: Mon Sep 06, 2010 12:33 pm
If you're running a lowered A-body and want a very good front shock you can use Bilstein B46-1104. It's a GM shock so you have to cut and remove the cross-pin at the bottom and insert the sleeve from the bottom of your old front shocks, but it's well worth the trouble. A friend is using these on his '68 Valiant with 1.20" torsion bars and reports excellent results. I'm about to pull the trigger and order them for my Barracuda. They are $40.58 each on Amazon. http://tinyurl.com/289ahma
OK, I did it. I ordered Bilsteins for the Barracuda. They will be controlling 1.14" torsion bars.
PostPosted: Mon Sep 06, 2010 4:44 pm
I’m running just a bit smaller size, 0.940â€￾ Firm Feel torsion bars, with an Adco anti sway bar up front, and cheep Monroe-matic shocks on all four corners.
The car corners flat, doesn’t keel-over in tight turns or nose dive during hard stops. Also, I have the Formula S Cuda stile six leaf rear springs out back. We have our share of rough roads in Maine as well, and this combination gives a nice solid ride, with out rattling one’s teeth loose. The ride is close to my 300C’s, perhaps a wee bit softer.
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 5 guests
