It is currently Thu Nov 26, 2026 8:31 am
 Post subject: Quick tune up.
PostPosted: Mon Sep 20, 2010 6:42 pm
Hi,
I've read through the stickys and have done most of the stuff.
I have a 225, with 350 holley, long runner intake (cheers aussie speed), extractors. heads been ported and polished, have the head shaved to 9.5:1 comp. Full new elec ignition setup with new MSD blaster coil.
My question is (and remember I'm pretty new to this stuff) I want to tune this engine a little, what are my options I'll have about $200 budget. And lets assume I don't have too many tools but I'm mechanically minded and a good learner.
Next step will be to get newer cam, and put in 1.70 and 1.44 valves etc.
Any help would be great, thanks.
PostPosted: Mon Sep 20, 2010 7:14 pm
Plugs, cap and rotor, set the timing, adjust the valves, then see how she runs.
It sounds like you've got a hot setup there! 8)
'78 Volare 225
'67 Charger 318
PostPosted: Mon Sep 20, 2010 7:37 pm
Cheers,
Haven't had time to let her rip yet, body is in pieces at the moment and I'm prepping for paint work. The ignition setup is about 4 weeks old, so guess I'll just get the new plugs. everything else is new.
Sounds good :).
PostPosted: Tue Sep 21, 2010 7:53 am
Would also suggest a Dizzy recurve.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Tue Sep 21, 2010 9:18 am
You really need to get the vehicle running & "on the road" so you can see / "feel" if there are any problems or where any improvements can be made.
You could already have a nice running combo... you just need to put some miles on it to "shake-it-out" some, before taking the next step.
PostPosted: Wed Sep 22, 2010 12:30 am
Thanks alot!
Sadly looks like it'll be around 6 months before the car is on the road :/ Doing all the paint work now + it's nearly $1000 just to register the car for a year etc.... :/:/.
As I said I'm still pretty new to this, does having a timing gun help with a dizzy re curve?
PostPosted: Wed Sep 22, 2010 6:44 am
A timing gun is just a plain good tool for car work. Use the search function and look at the FAQ's at the top of each section. There are several great articles on recurveing.
Ouch $1000 to register a car for a year. Thats got to hurt.
Frank
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
Users browsing this forum: Bing [Bot], Google [Bot] and 7 guests
