It is currently Wed May 27, 2026 6:36 am
 Post subject: Slant six engine paint?
PostPosted: Wed Sep 22, 2010 7:31 pm
Hi there
Couple of questions:
1. What is the paint code for the red-orangy 170ci engine paint and where to get/order?
2. Would you recommend an electric fuel pump or stay with the original mech pump? The engine is stock standard 170ci and is currently using "Mitsubishi" electric "tick-tick" fuel pump (the mech pump is not working).
Thanx for all the help guys.
Cheers
Cars: 1966 Dodge Dart 270 Convertible,
1990 Alfa 164 Twin Spark
1980 BMW 735i 5-speed
http://www.weddingcar4u.blogspot.com/
PostPosted: Thu Sep 23, 2010 5:29 am
Contributor
DupliColor spray cans available from most auto parts stores...Chrysler Industrial Red.
PostPosted: Thu Sep 23, 2010 9:00 am
I use mechanical pumps... mostly for noise control and reliability.
For high power applications, I will add an electric "pusher" pump, back at the tank, the plumb a second fuel line up to the carb. or N2O system. The electric pump gets turned-on when extra fuel is needed.
PostPosted: Thu Sep 23, 2010 7:32 pm
Got this reply from Dupli-color:
"Thank you for your inquiry. Unfortunately we do not have any distribution
of our products outside of North America. I apologize I could not help you
with this request.
Regards,
Jared
Dupli-Color"
Hmm...
PostPosted: Thu Sep 23, 2010 7:53 pm
There are two ways to get the Dupli-Color paint outside the USA...
1. Have a SL6er ship it to you
2. Obtain a color chip and have it mixed locally.
Ken
PostPosted: Thu Sep 23, 2010 8:12 pm
hi, see if you can get or search duplicolor #DE1632 chrysler industrial red for your engine. ronnie
PostPosted: Fri Sep 24, 2010 2:03 am
I have found that VHT engine enamel in bright red color (SP121) is a pretty good match to Chryslers red .
see if that brand is available where you are.
the same paint on my engine.
made in USA but if it is available in Australia,perhaps in Malaysia also?
regards,Rod
:D
PostPosted: Fri Sep 24, 2010 7:46 am
VHT is good paint. We use the ceramic version on headers, intakes and engines.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
