It is currently Mon May 25, 2026 4:29 am
PostPosted: Fri Sep 24, 2010 8:55 pm
im planing to get my duster back on the asphalt before dec,my manifold crack a while back so i finaly decided to taked a part,clean the engine for paint,i was removing 38 years of gunk when this happen,hope my pics work,how can i fix it,any of u had this problem,how hard to fix,please help
JASONImageImage
PostPosted: Fri Sep 24, 2010 8:58 pm
Site Admin
Are you talking about the block plugs?
Pop them out and install new ones. :D
Is there something else wrong in the photo that I can't see?
CJ
PostPosted: Fri Sep 24, 2010 9:26 pm
If one core plug is leaking, the others are not far behind. Replace all of them.
Ken
PostPosted: Fri Sep 24, 2010 9:44 pm
6 Pack Dart
Could you post a larger or clickable picture? I thought I saw what you were asking about, but picture is too small to be sure.
Richard
PostPosted: Fri Sep 24, 2010 9:49 pm
so it is a simple fix :shock: ,where can i get these parts,part #,pull old ones out,push the new ones in,is that easy as it sounds,no special tools :oops: thank you,
JASON
PostPosted: Fri Sep 24, 2010 9:50 pm
Aha,
Once I recognized what "things" on the left picture was.
What you are looking at is water squirting from hole of corroded core plug.
The right hand picture is core plug with hole visible.
1. Turn the core plug sideways with careful tapping with a flat tool rod on inside edge of cupped part.
2. grab the plug edge with favorite choice of tool and pull old plug out.
3. clean up the round surfaces where core plug sits on with sand paper, clean up and degrease well with acetone or like that leave no oily residue.
Clean up the new core plug with acetone or like.
4. Apply bit of sealer round the surface and round the edge of new core plug.
5. Drive it in carefully with a socket and a hammer, just below the edge of the opening.
Cheers, Wizard
PostPosted: Fri Sep 24, 2010 9:54 pm
Richard
sorry fopar,donno how to do clickable thing yet,thank you
JASON
PostPosted: Fri Sep 24, 2010 11:06 pm
6 Pack Dart
Wizard got what I saw but wasn't sure of.
When you drive the new soft plugs in use a large socket (one that almost as big as the recess in the soft plug).
Richard
PostPosted: Fri Sep 24, 2010 11:34 pm
thx everyone,now were can i get these plugs,i looked at ebay no luck,what kind of sealant should i use,thx guys
JASON
PostPosted: Sat Sep 25, 2010 12:42 am
any good parts store will have them. slant freeze plugs (we call them "welsh" plugs in Australia) are 1 5/8" diameter. they are available in brass also,which is a corrosion resistant alternative. cost a fraction more,but last heaps longer than steel.
regards,Rod :D
PS: a radiator repair place should have them also.
PostPosted: Sat Sep 25, 2010 5:51 am
Freeze plugs are available at any auto parts store. I use good old #2 permatex sealant. What ever sealant you use don't go overboard with it. just a thin coat on the rim of the plug knock them in and you are good for another 35 years. Cheers Cliff
This is my hooptie, there are many like it but this one is mine. With out my hooptie I am walking and without me my hooptie is broken down.
1980 dodge d150, sl6, 4sp od, air
PostPosted: Sat Sep 25, 2010 10:27 am
thx guys,ill be heading to my local autoparts store today,whats the funtion of these freeze plugs,anything alse that i need to do,get the hose and wash out the gunk in there i donno, thx for all ur replyes...
JASON
PostPosted: Sat Sep 25, 2010 11:46 am
6 Pack Dart
They are to plug the holes where the sand is removed from the casting, good time to check out how much crud is inside the water jacket.
Richard
PostPosted: Mon Sep 27, 2010 9:24 am
Yes, now is the best time to clean-out all the rust scale and "mud" that has collected at the back of the block's water jsckets.
Remove the lower radiator hose off the water pump (or remove the water pump) and also remove the thermostat cover.
Stick a hose into the head, where the theromstat installs and stuff a rag around it to get a seal, then turn-on the water, full power.
Use a long screw driver, long metal ros or coat hanger to poke around inside the water jackets, thru each freeze plug opening, this will break-up more crud so the water can flush it out.
Once flushed, re-install the freeze plugs and other items removed.
Do not use RTV silicon type sealers on freeze plugs, use something "sticky"... I use weather strip adheasive! :shock:
(I have had freeze plugs pop-out and it usually happens at max RPM / engine output... and can get the car " sideways" when that happens) :evil:
PostPosted: Mon Sep 27, 2010 10:53 am
thank you all for the helpfull replies,i got the brass plugs at $2 each,ill be taking care of this over the weekend,(I use weather strip adheasive!)
weather strip adheasive?sounds good ill give it a try,now if i remove the water pump should i check the timing chain?
Users browsing this forum: Bing [Bot], skraecken and 3 guests
