It is currently Sat Nov 14, 2026 5:23 am
PostPosted: Sun Oct 03, 2010 9:23 pm
Hi all
question. I have a 1970 dodge dart with the trusty slant 6. I was wondering if anybody knows if it has points or electronic ignition? There is an electronical box on the firewall but the ballist resistor is the two prong kind. I was told if it was electronic ignition it would have the dual ballist resistor type. the engine is all stock. if it does have points what is the electrical box on the firewall. any help would be appreciated.
PostPosted: Sun Oct 03, 2010 10:03 pm
How many wires are coming out of the side your distributor?
PostPosted: Mon Oct 04, 2010 4:12 am
Points spotter’s Guide:
Pop off the distributor cap, and look for a set of points articulated from the six sided cam mounted on the distributor’s shaft. [url=http://www.summitracing.com/parts/SMP-CH14XV/?rtype=10]This thing[/url].
Electronic Ignition spotter’s guide:
Look for a six blade reluctor, that is, six vertical fins pointing out from the distributor’s shaft. [url=http://www.townautoparts.com/Standard-Motor-Products-Reluctor/A/B000C81JR8.htm]This gismo[/url]. Additionally there will be mounted in the engine compartment an [url=http://www.yearone.com/serverfiles/fbshopmain2.asp?pid=FDP505&c=0&e=0&cat=1&hid=112BL3889&trk=3] “Electronic Spark Controlâ€￾[/url] often orange in color, but can be black or chrome, or something all together different from an after market company.
PostPosted: Mon Oct 04, 2010 4:09 pm
If it is still stock it will be points and the "electronic box" should be the voltage regulator.
50 chrysler,54 Plymouth, 64 Valiant conv 4 speed, 66 Valiant V8 wagon, 70 Challenger R/T 440+6 conv 4 speed,80 Colt, 98 Neon ACR,84 Honda V45 Magna
Taking care of 57 300C conv,48 T&C conv. Missing my 67 GTX and 36 Ply coupe
