It is currently Tue Nov 18, 2025 5:58 pm
 Post subject: Fuel Sock
PostPosted: Mon Oct 11, 2010 10:41 am
So I've dropped the tank on my '63 wagon, and am preparing to have it vatted/boiled/lined. Removed the sending unit, and the sock is toast. Given I'd like to do this as cost-effectively as possible, I'm going to clean the sending unit with carb cleaner to remove all the crud. Is the sock a replacement part they sell alone, or do I need to buy a whole new sending unit? I can't quite tell how the sock comes off - is it screwed on or just press-fit onto the fuel pickup line?
PostPosted: Mon Oct 11, 2010 11:11 am
The first time I bought a new sock from a Paddock (now gone), and the next time, while the Chrysler dealer couldn't sell me one, a Ford dealer could. Most are 5/16", a very standard size, and it just slides onto the tube. I've never been able to remove one w/o breaking it to pieces in the process - they get very brittle with age.
PostPosted: Mon Oct 11, 2010 1:34 pm
Thanks. Anyone have a current source for replacement socks? I'm about to Google search them. My aftermarket parts places here in LA (Pep Boys, Autozone, etc) don't have cylindrical strainer socks like these are supposed to have. And a couple dealerships have told me they only sell the entire unit.
PostPosted: Mon Oct 11, 2010 4:07 pm
Send a pm to slantsixdan or Josh Skinner. I can't remember which one of them has the part number. I believe you get it at the Ford dealership. I had to buy a sending unit gasket, fuel pipe grommet and a sending unit sock. I used their part numbers and ended up going to the Dodge, Chevy and Ford dealerships to get everything.
PostPosted: Mon Oct 11, 2010 7:00 pm
Here are the numbers for a '65: float, strainer sock, gasket
BTW, it is listed as a 'Fuel Tank Gage Strainer'.
Olaf.
Aspenized
PostPosted: Mon Oct 18, 2010 7:31 am
just one for my '66 from YearOne $18.
'66 Dart Wagon 270, 225ci/904, Survivor!!
'68 Dart Hardtop, 383/727 & 3:91 gears
PostPosted: Mon Oct 18, 2010 10:10 am
Thanks guys! Found a source for one not five blocks from me for $18 that I was able to pick up day-of.
PostPosted: Mon Oct 18, 2010 12:49 pm
I see you mention lining the tank,might check out this outfit,not cheap but a member on another forum swears by them.He had one done 6 years ago and says it still looks like new.
http://www.gas-tank.com/
