It is currently Thu Jun 18, 2026 5:47 am
PostPosted: Tue Oct 26, 2010 6:02 pm
Car Model: 1973 Plymouth Valiant Sedan
Hiya! I'm about to install a brand new, never run, Holley 1945 into my '73 Valiant in place of the crappy, leaky Holley 1920 I've been running. I've pretty much got the conversion figured out, except...
Does anyone know what the Tee pictured below is for? Should I just cap it?
Also, I don't have any experience at all with 1945's. Does anyone out there have any advice? Things I should be aware of? I do plan on checking out the training videos, but I figure nothing beats the advice of someone who's had hands on experience with these. Anyone information that can save me "trial and error time" is GREATLY APPRECIATED!!! Thank you!!!
-Matt
PostPosted: Tue Oct 26, 2010 6:25 pm
This nipple at base means manifold vacuum. Use tee for other stuff that needs manifold vacuum or change hose for longer one and omit the tee.
This is choke pull off diaphragm. Make sure this is adjusted correctly.
Cheers, Wizard
PostPosted: Tue Oct 26, 2010 6:28 pm
The T is probably for the thermostatically controlled air cleaner.
PostPosted: Tue Oct 26, 2010 7:06 pm
Yep.
PostPosted: Tue Oct 26, 2010 10:37 pm
See the open port coming out of the side of the carb in the picture above? All of the diagrams I have found showing how the 1945 should be properly installed identify that port as what should be hooked up to the air cleaner.
So it would be easiest for me to go with Wizard's advice, especially since I'm not using EGR,vacuum amp, or any other vacuum related things, I could just cap it.
But if anyone else has an opinion about this I'd like to hear it.
THANKS!
-Matt
PostPosted: Wed Oct 27, 2010 12:10 pm
On my setup I run a line from the vacuum gauge to the "T". If your not running a vacuum gauge or the original pollution control, cap it.
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 3 guests
