It is currently Mon Oct 26, 2026 12:02 am
PostPosted: Wed Jun 04, 2003 10:20 pm
I saw the 62 hyperpak at the slant six show at clifford last weekend- It concerned me the hood was cut to fit the air cleaner. I want to put one of these manifolds in one of my 61 Valiants but I am not willing to sacrifice a hood. I looked back through photos of the Nascar Valiant, Falcon, Corvair race to see if the hyperpak Valiants had their hoods cut - None of them did - the setup they ran fit under the hood.
Is the Clifford hyperpak a taller setup than the original? Or did the 62 I saw at the show just have the hood cut to get the cold air advantage?
BTW - Clifford claimed to have the Hyperpaks in stock today - so I put my order in. We will see how soon they deliver.
PostPosted: Wed Jun 04, 2003 10:56 pm
According to most sources, the element/pie tin wouldn't fit so they either ran without one or made something work to get the hood to shut...
PostPosted: Wed Jun 04, 2003 11:23 pm
You can get a decent air cleaner onto a Hyper-Pak "low block" 170 but hood clearance become pretty tight with the taller 225.
The factory used an air cleaner withan off-set base to help move the air cleaner more towards the center for more hood clearance.
PostPosted: Thu Jun 05, 2003 3:48 pm
I've seen an Abod Barracuda complete with Hyper Pak and offset Shaker hood in an old Mopar Magazine. That'd be cool.
It is easier to REACT,
than it is to THINK!
Middy.
 Post subject: Clifford delivered !
PostPosted: Wed Aug 06, 2003 11:21 pm
Well it only took two months and a few days for Clifford to deliver the manifold that was "in stock". I guess there are somethings for which you must wait. And on the plus side they did deliver - not like the ebay hyperpak which I never saw. But that is another story.
Let the fitting, grinding, and engine building begin !!!
PostPosted: Thu Aug 07, 2003 8:26 am
Hope you didn't get the one I sent back.
Cecil
PostPosted: Thu Aug 07, 2003 8:38 am
For the Air cleaner how about a 14inch circular baseplate a thin spacer and a X stream lid might be good for a low profile setup?
Middy.
PostPosted: Thu Aug 07, 2003 2:16 pm
I looked through the runners and inside the plenum - It has some casting flash (or slag) but it is not one of the ones that had the photos posted.
It looks like I will need to get a dremel tool with a long flexible feed to
remove the casting flash from the inside of the two middle runners - the rest looks pretty clean. I haven't done a check fit on the head yet (to
see if the mounting holes are lined up)
As for the Air cleaner - I bought a 14" x 2" (maybe 3") offset setup
from Summit. The offset will keep it from getting into the fender
area where the hood is rolling off.
I am putting it on a 170 - so that buys me an inch on the
height - Probably will also skip the adapter Clifford sold me - just drill
and tap the carb pattern into the manifold directly - that will give me
another .5" on height. It still looks real close - Sure hope I don't need
to cut the hood.
PostPosted: Fri Aug 08, 2003 3:34 pm
Im putting a h-p on 60 valiant but I cut an off set scoop off of a mid 80's trans am hood and I am mating to my val hood.I know this sounds weird but it looks really slick and my car is not gonna be exactly" stock" anyway.
SlantedAttitude
 Post subject: Any Pics?
PostPosted: Fri Aug 08, 2003 3:37 pm
Slanted you got any pics of that - I love custom stuff.
Cheers!
Al T
 Post subject: Offset
PostPosted: Fri Aug 08, 2003 3:49 pm
I seen an offset air cleaner assembly in a recent Jegs or Summit catalog. It was in the section with stock car stuff. Might help a little?
Rick
Users browsing this forum: Bing [Bot] and 14 guests
